Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore 25358082896 I used pressure air to clean under my side by side Kenmore 25358082896 fridge. my coils was frozed. deiced it. checked to defrosted relay that is connected to the coil by ohms using can of cold air it worked. put everything back. It defrosted a few times. Now the refrigerator side it not cooling as well again and the coil do not seem to be defrosting
  • gvictor Aug 22, 2008
    Defrost thermostat was my problem. Due to time of use, the inner part had separated from the metal case. What I did was pushed it back in. The inner part is made of some sort of hard plastic. I used a small punch to indent several places all around it. Just enough so it will hold to the hard plastic material. It been three weeks now it still defrosting like it should. But I still brought a new one since I know the problem just in case..
the dr
  • 447 Answers
SOURCE: GE side by side Refrig. with evaporator iced up solid.
Yes ill be glad to help John. Your refrigerant level is fine. Remove the motherboard axcess panel on rear of refrig. Locate 3 wire blue plastic connector on bottom of board. Wires are labeled Comp, Line, Def. Jump Line to Def and see if heater gets hot. If nothing happens than replace the heater. Let me know what happens.
Posted on Dec 04, 2007
  • 50 Answers
SOURCE: GE refrigerator TBX25zpk coils Freezing
It's almost always the defrost heater. If you have volts to the defrost thermostat the defrost control is working. Set your meter to check ohms and remove the wiring from the heater. If anything changes when you touch the meter leads to the heater terminals then the heater is probably good, but my guess is nothing will change, which means you've got a bad heater.
Posted on Jul 21, 2008
breddi2
  • 126 Answers
SOURCE: Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Posted on Jun 16, 2009
localwonder
  • 6784 Answers
SOURCE: after defrosting my kenmore compact refrigerator,
Ok, this unit will need a recharge asap. this is the result of a low-refrigerant state.
Posted on Jun 19, 2009
I have an eight year old fridgedare gallery side by side fridge.this morning its freezer is working ok but fridge side is warm.feels like no air is comming to the fridge.feels like there is some ice build...
Sounds like the evaporator is froze up. You may have a defrost problem. First I would check and see if the condensor coils on the bottom, if they are, clean them. I cant look up a wiring diagram without model and serial #'s. Do you know where the defrost timer is? hope this helps.
Oct 23, 2011 | Refrigerators
. kenmore side by side blows warm air, after
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 30, 2011 | Kenmore Side by Side Refrigerator
Runs continuesly and does not go in to defrost or cool the fridge
hi,on the back wall of the freezer,is there ice...if so you have a bad defrost sensor or heater...if froze up,when you remove panel...if ge replace white sensor on coil an heater at bootom...if regular frig ..replace round disc with two wires on copper tube...if iced up coil..deice with blow dryer,,,unplugg frig first...also check heater...hope it helps....michael doctor airr appl.repair 843-384-8474..call if need assistance..good luck..
Mar 26, 2010 | Refrigerators
Return air duct frozen over
check to see if the evap fan is running inside freezer.
clean cond coil under back of fridge.
check if evap coil inside freezer is froze over, if fan is running and cond coil is clean, it may need a defrost timer.
Sep 24, 2009 | Refrigerators
Freezer cold but fridge not
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 23, 2009 | Kenmore 64802 Top Freezer Refrigerator
Re GE TFX26ZP sid by side fridge Evaporator coil keep ice on it
the defrost thermostat should be clamped onto the evap coils..defrost timer should be under fridge. If this is a newer model, it might have an ecm ( comp control) on top of the compressor..
Sep 21, 2009 | GE GSL22JFR Side by Side Refrigerator
Ice build-up in lower freezer. We replaces the
warm between doors is normal. if hot then clean coils and if coils clean make sure condenser fan motor working thats the fan in the back compartment, however if warm thats good. did the evaporator coil freeze from top to btm is that why u replaced heater. if it was then could be heater,if the coil is only getting frost on half the coil,you could have a sealed system problem. is the evaporator motor working in the frz side if not,then that could be the problem.if coil is froze up it needs to be defrosted. did you defrost coil when you replaced heater,if not try defrosting coils and then wait about 12 hrs and see how it does.
Sep 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice melted and fridge not cold enough kenmore 363.50622000
Several things possible - fan in freezer side not running, defrost thermostat not working, if fan runs and cuts off & on, then the defrost heater strip could be out, but check the defrost timer under fridge; not cycling, you can manually turn to see if fan cuts off and on. If you have "ice shelf" in coils on freezer side then no air circulates in freezer and over into refrigerator side.
Aug 14, 2009 | Kenmore Refrigerators
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore 50222000 help me please
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Oct 19, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
