Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
WASHER OFF FULL OF WATER
WASHER CAME BACK ON AFTER SLAMMING THE WASHER LID
  • 246 Answers
Have you tightened the screws on the hinges? If they get loose, the lid switch will only get an intermitent contact. There are 2 phillips screws on each side of the lid.
Posted on Jul 20, 2008
For awhile now i have been having to slam the lid to get the load to finish after it first fills up with water. Now today even slamming the lid wont work. HELP
you have 2 screws on each side of the lid, make sure they are thight. one side of the hinge activate the lid switch. if that dont work then you damage the lid switch. replaced.
Feb 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My Kenmore washer 26 26962 MO 110 26962503 will start the cycle..
It sounds like it is your water level control. Here is a link to the Kenmore site which has your manual use these numbers ( Kenmore washer 26 26962 ) for your model unless asked for more Kenmore Manuals
Oct 09, 2009 | Kenmore 26882 Top Load Washer
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a ge profile wpre6100gwt top load washer it will drain water but will not agitate or spin
I would check your belt. From what you've told me, your electric pump is working and receiving power from your lid-switch, but your motor and transmission is not turning/agitating.
Meaning, your belt is most likely, NOT engaging or grabbing your pulleys to rotate the motor/tranny. Belts will ware and tare, just like your vehicle fan belts. Change it! You should be good!
If not your belt, your lid switch may be the culpret. However, from what you've described; very unlikely because your water pump is turning on and receiving power from the "lid-switch". The switch becomes defective after constant use and slamming/dropping of the door. The purpose of the lid-switch is to prevent accessing your clothes when in spin-cycle (dangerous)
Dec 26, 2008 | GE Profile WPRE6100G Top Load Washer
The load won't start.
It sounds like you have a bad lid switch.It's an easy fix.You can get the part at your local appliance supply.
Dec 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Remove top of machine, you will find lid switch or 'sensor' there. I would say its faulty ,and needs to be replaced.g,luck.rate me
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Water fill stops
Your lid switch is probably damaged or loose. Examine the lid switch on the right-hand side of the washer tub opening. There are two screws that hold the switch in place. Check to see if they are loose. In addtion, the lid should have a small plunger that depresses the switch when the lid is closed. Make sure it is intact and not broken. If the switch is tight and the plunger is intact, the switch has probably been damaged and needs to be replaced. If you have the type of washer that has no visible plunger and/or switch, the lid switch is locate in the rear on the left hand side and has a small arm attached to the lid that activates a contact when closed. Often this arm can get bent and will not engage the lid switch contacts. A simple adjustment (sometimes) can correct this. I've seen a lot of these switches where the casing on the switch separates and the contacts will not close. Slamming a washer lid is highly NOT recommended just for this very reason. The switch is an easy replacement and costs roughly $35. If youy post back with your model number I can research to find a part number for you. I will also give you step-by-step instructions on how to replace it. I hope this helps.
Oct 12, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
