Question about Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator
Frost on the back of the freezer and temps too high
I have a Frigidaire side by side, model PHSC39EESS and the temps are too warm along with frost on the back of the freezer. I have previously had a tech come out to take a look and he put the fridge into a manual defrost mode some how and everything was fine for a few weeks until now. When he did so, the temp controls read 'DEF". He mentioned that the control panel may need to be replaced. I have read that hitting the light switch 5 times w/in 5 seconds would put it into a manual defrost but I can't locate the light switch. I was hoping to get it defrosted until further assistance can me had.
  • Frigidaire Master
  • 5,568 Answers
He may have meant the interior light switch that is operated by the door(s).
That is normally an exposed button along one side of the door frame.
Posted on Jul 19, 2008
Frost on the evaporator
watch this video I made. this is subzero with low level of freon (almost out). same situation on all refrigerators and freezers. you can see ice at the begging of evaporator. if there would be a little more freon evaporator might of frost up at the top might frost half of evap other half would be not even cold.
Jan 28, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a GE model TFX30PPDACC. It had frost in the freezer on back panel. Changed defrost timer and defrosted the coils. Lasted 10 days before enough frost built back up and refrigerator temp climbed....
thats what it will do when nothing frozen is in the freezer,you should hear the defrost heater popping if theres frost or ice melting off the evaporator coil in the rear area of the freezer its working ok
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
My Frigidaire freezer (not frost free)won't stay cold
look at level side to side , and front to back. if not level door can leak . you will see water where it is leaking. check defroster is if staying on .
Feb 18, 2018 | Frigidaire Freezers
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
May 24, 2009 | Freezers
Layer of frost on the bottom surface of ice maker
during periods of high humidity and or high use, it is not unusual to notice frost on surfaces in the freezer. the ICM is susceptible due to it being metal and having warm(compared to freezer temp) water in it. make sure the doors ar closed tight and nothing is stuck in the gasket area.
Jun 13, 2008 | GE Profile PSI23NCR Side by Side...
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Feb 17, 2008 | Frigidaire FRS26ZSG
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice build up in freezer
Sounds like a defrost problem... need to pull back panel off in freezer and see if u have thick frost build up indicating... heaters, or defrost themostate bad.. could not bring up your model # SO dont know if maybe bad defrost timmer or if you have adaptive defrost control which could also be bad.
Aug 19, 2007 | Frigidaire PHSC39EESS Stainless Steel Side...
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator Logo
162 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
