Question about Hitachi 53UWX10B 53" Rear Projection Television
DP23 LED not lit on deflection board no picture on tv
Problem started with blue convergence not lining up. replaced red and blue ics and RK50 and RK54 resistors for hitachi 53uwx10ba. connected and powered up tv - 5 minutes into warm up picture started to go. picture went out. tv will power up - red power light is on and all LED's are on except LED DP23 on deflection board. TV powers up but no picture or sound. Have full schematics for tv but unsure where to go from here. NOT a tv technician and trying to fix on my own. Not sure what to do now. Any help would be much appreciated.
Thanks,
Gil
  • 927 Answers
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Posted on Sep 01, 2008
Was watching tv there was a flash of light picture went out and no sound either red led power light comes on but thats it no pic no sound
Replace Both of your STK ICs nd 6 resisitors they are big black ICs will have part # on them STK392-110s .
RK42-RK 46-RK50-RK54-RK58-RK62
3.3) -( 1.8) -(2.7 ) (1.5) (3.9)- ( 2.2ohms)
Sep 25, 2009 | Hitachi 51SWX20B 51" Rear Projection...
I changed the IC chips on my hitachi 53uwx10b tv like you guys said that helped alot but still have wavey lines on both sides of the screen what do I change on the con. board now? Thanks alot Jim
Resistors " RK42 3.3ohms
RK46 1.8ohms RK50 2.7ohms RK54 1.5ohms RK58 3.9ohms RK62 2.2ohms After you replace all of them then enter convergence by pulling OFF bottom front panel there on front of convergence board is a small blue button press it and a convergence pattern will come up now aline each color red then blue.
Sep 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Tv's picture is messed up.
Symptom: Blue convergence off, bowed inward at the top and bottom with No blue vert movement.
Cause: Replace IK05 (STK392-110) and RK54 (1.5 ohm/1W) and converge. RK50(2.2 ohm/1W)
Sep 20, 2009 | Hitachi 43FDX01B TV
Looks like the picture is in 3D...magic focus won't adjust green
Replace Both of your STK ICs they are Big Black ICs Also CK and replace these resistors RK42 3.3 /RK46 1.8 /RK50 2.7/ RK54 1.5 RK54 1.5/ RK58 3.9 /RK62 2.2
Feb 15, 2009 | Hitachi 57F500 57" Rear Projection...
Blue droopy line in middle of tv, everything yellowish above
Your convergence ICs Stk-392-110s Replace Both ICs.If 110s use 180s if 020s use 040s other wise Go by number on ICs .Mat electronics has parts 1-800-628-1118.Thats Cheap for 300.00 if you only have to replace ICs! Check all resistors around ics replace them if burt/read bad.RK42 3.3ohms RK46 1.8 RK50 2.7
RK54 1.5 RK58 3.9 RK62 2.2 ohms.
Jan 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Convergence on a 61
Have you replaced any of the resistors? RK42 3.3ohms /RK46 1.8 RK50 2.7 / RK54 1.5 / RK58 3.9 / RK62 2.2 ,ALSO remove front cover on TV looking at front of chassis is a button on board that has ICs/ press and hold for 3 secs with TV on ,then up should be convergence Pattern for alinement.
Jan 03, 2009 | Televison & Video
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Blue won't line up at the top in digital array
you need to replace both convergence ICs and the six 1 watt feed resistors. The ICs are both STK392-110 and the resistors you need one of each RK42 3.3 ohm 1watt, RK46 1.8 ohm 1watt, RK50 2.7 ohm 1watt, RK54 1.5 ohm 1watt, RK58 3.9 ohm 1watt and RK62 2.2 ohm 1 watt.
You can get replacement ICs and resistors at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 15, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Blue convergence
Thats the classisc sign that you need to replace both convergence ICs. You will need two Convergence ICs STK392-120 and then six resistors they are RK42 3.3 ohm 1watt, RK46 1.5 ohm 1watt, RK50 2.7 ohm 1watt, RK54 1.5 ohm 1watt, RK58 3.9 ohm 1watt, RK62 1.8 ohm 1watt. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can repair the set yourself. Heres the link.
Jul 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
302 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
