Question about HP 1220xi Plain Paper Inkjet Fax
Problems with copying
Every time I try to copy something there is black line coming across my copy page.
    Genius:
  • 2,120 Answers
Pull front of fax machine open
look down
clean the little glass ****.
Posted on Aug 31, 2008
Black lines print on black and white printing
Sounds as if the drum needs to be replaced if it does this on copies and prints.
If it just happens on copy when using the document feeder then try cleaning the narrow piece of glass that is located just to the left of the large piece of glass.
Jan 09, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Error code F2-42
Are the lines horizontal or vertical? DO you get lines on B/W copies (black and white) also? If you try to copy a blank white page do you get the lines? Does the toner / lines wipe off after the copy comes out? If the toner wipes off after the copy comes out you have a problem in the fusing unit ( the hot area that fixes the image onto the page). If the lines are vertical then you have something inside the device that is dragging across the page as it goes through the device. If the lines are horizontal then you it could be the drum cleaning blade, the transport blade, or charge roller. The noise could be that one of the blades are bouncing. It could be that a gear is worn. Please give more info on the problem to better help.
Dec 31, 2008 | Sharp AR-BC260 Color Copier
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Jul 22, 2008 | Canon PC-940 Black and White Copier
PC940 dark lines across the middle of the page
Either the Fuser/Heating unit is bad, or the optics are dirty.
What you can try to do to narrow it down, is to make a copy but.. STOP the machine in mid process by turning the power off. This will create a paper jam in the machine. If timed properly, your copy should be 1/2 way through the machine with some image on it. (Make sure that you are trying to copy something on the glass). The copy is not FUSED, so the toner will wipe off so be careful not to rub the page against your clothes/sleeve. IF the black line is on the page at this point, the problem is not in the fuser but probably in the fiber optics. If the problem is in the optics and will need to be cleaned. If the black line is NOT on the page at this point, then the fuser unit is bad and needs to be replaced.
Let me know how the copy comes out when you stop the machine in midway and I can see if i can give you any more suggestions.
Good luck.
Mac
Feb 12, 2008 | Canon PC-940 Black and White Copier
Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
HP 1220xi Plain Paper Inkjet Fax Logo
66 people viewed this question
Ben Johnson
