Question about Sharp Actius GP22W Notebook
No Sound The audio on my Sharp Actious GP22W disappeared a few days ago. I've gone to the Control Panel and checked all settings that I can think of. This happened once before and after much searching, it was suggested that the computer had been in stand-by mode and had turned off sound automatically to conserve energy. I followed his instructions to use one of the function keys to turn the sound back on. Unfortunately, I can't remember which combination of keys worked. I've tried the Fn key, Shift, and Control in various combinations with the F keys, but nothing has worked so far. Any ideas for further troubleshooting will be much appreciated!
There is no sound
Posted on Aug 05, 2009
I have a Sharp Aquos LC-46D43U TV and the audio control is continuously going down to zero although I use the remote to increase the volume. The TV is automatically decreasing the volume to 0. I hea
this is a problem I rectified yesterday.
the audio ic is overheating thats why the tv is fine when cold and
after a few hours the volume disappears.
I fitted a heatsink to the ic chip as the sharp one is very poor quality
Sep 19, 2014 | Televison & Video
The sound icon has disappeared from the task bar. I've checked control panel (sounds and audio devices) and the 'place volume icon on task bar' has gone grey and can't be ticked (it was ticked before icon...
hello from a few days ago I was working on my laptop and suddenly reboot. but now get a message that is:
sis UNDI, PXE-2.1
copyright PXE BootROM v1.09f - ZL5_0324 Use BEV/BBS
=== Press <Esc> to bypass LAN check. ====
him and tried to boot from the CD drive. order to retrieve information or other cases formatting. but when the process goes to the information is not in the hard disk.
Aug 17, 2013 | Dell Inspiron 1501 Laptop
Rear speakers not working after formatting the system. Please. Help.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 06, 2012 | Audio Players & Recorders
I have a Sharp Aquos tv which repeatedly turns itself off. Can anyone help?
Try going into the menu on the control and change the power saver off, or the sleep programe turn them all off.
Mar 23, 2012 | Sharp Televison & Video
I have an HP Pavilion 6000dv...specifically, it's a 6119us. I have no sound at all. I've checked the device manager, nothing is muted, I've gone through the troubleshooting program...still...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 28, 2011 | Computers & Internet
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
Dell Studio 17 windows 7/ Sound disappeared completely.
The best thing to do would be a system restore. You might have installed some software or changed some settings which made the sound disappear.
Click on Start>All Programs>Accessories>System Tools>System Restore and follow the on screen instructions.
Jul 22, 2010 | Dell (8H390) Sound Card
Hi, I have an Acer D150 and I have no "sound icon" or audio at the moment. I think I deleted the audi/sound/icon by mistake a while ago.
If you are referring to the sound icon that's in the system tray (down by the clock), you may go to the Control Panel and create a shortcut.
1. Start > Control Panel > Sounds and Audio devices
2. Put a check on the box of "Place volume icon in the taskbar" under the volume tab.
If you are referring into another sound icon, please let me know. Have a great day!
Sep 13, 2009 | Gigabyte Computers & Internet
No audio on select channels
Go into the TV's menu and see what type of audio mode its set on. If it says sap turn on to stereo or mono. If it says stereo, set to mono. Also try to unplug set for 12 to 24 hours.
Sep 03, 2006 | Sharp 25R-M100 25" TV
Sharp Actius GP22W Notebook Logo
106 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
