Question about JVC Audio Players & Recorders
I have a JVC RX3 Stereo Receiver that will play no sound, i believe i had a short in the speaker wire, what is the fix for this?
djnick989
  • 1067 Answers
SOURCE: sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Posted on Feb 02, 2008
SOURCE: HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Posted on Feb 24, 2008
Benimur
  • 6966 Answers
SOURCE: I have a Kenwood KR-V7030
Since it was just recently installed, would it be safe to assume that it is fairly new? If yes, perhaps your best bet would be to return to dealer/manufacturer for repairs/replacement. It is highly probable that the unit has sustained major hardware fault at least on the right channel. Even if it were just a fuse, it would still be to your advantage going that route.
Should for some reason you would venture a DIY, diagnosis and repairs of course would require fair familiarity with electronic components and circuitry, use of a VM and a soldering iron and preferable access to a service manual or at the very least a schematic diagram with voltage readings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 29, 2008
killer_clown
  • 86 Answers
SOURCE: onkyo tx-sv727 Protect displayed
first thing if it says protect, check the fuses inside the system they may of blown .When choosing wire gauge, consider the quality of your components and speakers, the overall sound quality you're trying to achieve, and the budget you're working with. Also, keep in mind the distance between your receiver or amp and your speakers long wire runs can cause significant power losses, and thus require thicker cable. You can use this as a guideline
Distance from speaker to amplifier Gauge
Less than 80 feet 16
80 to 200 feet 14
More than 200 feet 12
Posted on Nov 03, 2008
  • 119 Answers
SOURCE: Proper hook-up from Denon AVR-1500 receiver to muti speaker box
Ok, All the spkrs from around the house get pluggeg into the spkr selector box out to spkrs and on the back of the Denon plug wires to connect the spkrs A to the spkr box and that should take care iof that for you
Posted on Feb 25, 2009
My receiver only plays front speakers. when i put it in surround mode none of the speakers will play and the sub even in stereo mode is barely a whisper of sound. i dont have a remote for it but it goes...
you don't need a remote. to me sounds like you might have a connection problem. try and do a test tone which will send a test signal to all the speakers. starts from left to right etc. if you cant hear all the speakers you need to check all connection wires etc. hope this helps
Apr 08, 2014 | JVC RX-8000V Receiver
Jvc receiver
What model JVC stereo?
May 26, 2013 | Audio Players & Recorders
What does it mean when my JVC stereo system comes on but there is no sound coming out
The problem is in the audio output ic, "loading system" first check that the speaker wires are not shorting, If okay! the audio output ic must be changed.
Apr 03, 2012 | JVC Audio Players & Recorders
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
http://www.pyleaudio.com/sku/PD1000A/1000-Watt-AM-FM-Receiver-w-Built-in-DVDMP3USB
Jul 10, 2011 | Audio Players & Recorders
My jvc kd-r610 car receiver is not playing or anything. I blinks "protect"
JVC head units go into protect mode usually when there is a short circuit on one of the speaker wires. Sometimes this is just caused by moisture in the doors or wherever the speakers are located. The first thing to do would be to reset the unit and see if it fixes the problem. To reset the unit there is a small button behind the faceplate which you will need to push in with a pen or other sharp object. Hold this button in for a few seconds. This will reset the head unit to factory settings which does mean that you will lose all of your saved radio stations, audio settings, color settings etc. If this does not work then one of your speaker wires is probably damaged. To find out which one unplug all of the speakers, reset the unit and plug them back in one at a time. When the unit goes into protect again you have found which speaker is causing the issue. Cheers, Dan
Apr 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
Hi i have a older jvc stereo and i have klh audio system model 9706 satellite and i do not know how to do the wiring i can get three spks workig but thats it can u help me do the wireing my jvc has 4 spk...
You can use 4 speakers. Connect 2 speakers to the A system of the JVC and the other 2 to the B system. Then select in JVC the A+B speakers position. As your receiver is stereo, this is the way you could best distribute the sound. However, if you have only 3 speakers, it would be dangerous to try wiring the third one without changing the whole impedance. So you may use 2 speakers.
Sep 08, 2010 | KLH HTA-9706 System
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
Sound/Ground problem
bad connection in one of the speaker wire.
Apr 02, 2009 | JVC AM FM CD DET FACE CAR STEREO
AV Receiver - Sound not getting through to speakers.
Before you do anything else, make sure no tiny strands of speaker wire from one channel haven't got in contact with the speaker wires from the other channel. Check first on the back of the receiver, then at the back of each speaker.This can cause the circuit breakers for that channel to shut it off when there is audio. It can also blow the fuses inside your receiver. It only takes one tiny strand to blow your amp.
Sep 22, 2017 | JVC Audio Players & Recorders
37 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
