Question about Canon PowerShot A95 Digital Camera
After resetting to default settings, the shooting mode screen is black
I reset camera to default settings in order to do some close-up shots.
Now, shooting mode does not seem to work. Screen is black.
View mode does.
How do I program things in order to shoot anything ?
  • Canon Master
  • 2,794 Answers
Remove the batteries and put them back in. See if it restores the camera seettings.
Posted on Jul 19, 2008
Hi, the photos i take are getting blurred and the image is not at all clear no matter how shot the distance may be i click the image.the only new icon i see on the screen is vibration warning symbol along...
If you are shooting in Auto mode with flash, this should solve your problem. Make sure you are not dictating any of the settings, i.e. choosing a longer shutter speed, a very small aperture setting, or a very low ISO (sensitivity) setting.
Typically the vibration warning icon will appear when the camera is trying to use a long shutter speed without flash in order to get the right exposure for a darker scene. Your outdoor (bright light) photos are probably OK.
In dim light with a point and shoot camera, you can have your choice between 1. blurry (using a relatively slow shutter speed), 2. dark (using a shorter shutter speed but no flash), or 3. a good photo with flash (which uses a medium shutter speed and added light from the flash)
Mar 12, 2011 | Cameras
Camera Canon Power shot SD800 IS, LCD screen shows much speckling. Also in telphoto mode the pictures are grainy.
try restoring your camera to the default settings, in most cameras theres a option for this in the menu, or there may be a reset button to press to get it to reset everything back to factory defaults.
lets see how the things are after this
Sep 05, 2008 | Cameras
Bought a Nikon P100 to replace a basic point and shoot dital camera. With children in sports, a shot from the stands is hard to 'get.' Now, all I get is blurry messes, unless it's in auto mode. Even the...
This camera is a bridge between the Point & Shoot (P&S) types and a "full blown" dSLR camera. It is very complex when compared the P&S type.
There are many areas of the manual the discuss the focus procedure, but you might want to simply perform a "RESET ALL" on the camera. This will return all the settings to their DEFAULT factory settings, thereby clearing any custom setting that could be responsible for the problem you are having. The instructions on how to do this and the settings defaults are shown on pages 171 through 173 of the manual. You will probably want to review them quickly before initiating the process.
After the reset, try taking some pictures to verify the focus works again. Next, feel free to change any setting from the default to one of your liking. Be sure to take a picture after EACH setting change to make sure you don't find yourself in the same situation again.
I hope this helps. Please rate my reply - thanks!
Jan 11, 2011 | Nikon COOLPIX P100 Digital Camera
My canon ixus70 will not take photos,I can view past photos but it will not show image on screen or record digital image ,if I take a shot all I get is a black nothing. Janis
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD750 and SD1000.
Resetting Settings to Their Default Values - PowerShot SD750 and SD1000. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd750resetscreen.gif 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd750resetscreen.gif 4. Select [OK] and press funcseticon.gif.
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language] and [Video System] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • Newly added My Camera settings
Jul 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Black lcd screen on Ixus 70 shows icons but will not take picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I can't view my pictures after the shot,it very blerr
I'm not sure if you are talking about the quick view of a picture just taken, or using playback mode to view shots taken. Either way, I suggest changing batteries so they are fresh.
There are 3 different LCD choices when in "Shooting Mode."
Press "DISP."
The display mode will change each time you press this button.
1- Standard (no info displayed, just pic)
2- Detailed (infor displayed)
3- Off
If you have tried this, then you may want to perform a reset to the cam. This will reset any screen/LCD settings that may have been changed.
Goto the Setup Menu and select "Reset All." Select "OK" and press "Func. Set."
This reset WILL NOT reset the following:
-Current Shooting Mode
-Date/Time, Language, & Video System settings
-White Balance Data (of you have custom settings changed in the custom white calance function)
Apr 30, 2009 | Canon PowerShot A450 Digital Camera
Digital Zoom and Auto Focus "On" settings are not kept/retained
If you shoot in the P mode setting and then go to the Menu and set the option for All Reset to OFF. The camera will retain those settings when powered off. If you are shooting in the AUTO mode the camera will always default back to the factory setting of OFF when the camera is powered off. The All Reset function is not able to be set in the AUTO mode because the camera is already using factory default settings.
Feb 24, 2009 | Olympus Camedia C-765 Digital Camera
Olympus FE-310
The reset option is located when you hit the Menu button when in shooting mode - it is on the left hand side of the screen. You would click Reset and press Ok. It will show Reset Yes or No. Select Yes and press Ok. The camera will now be in factory default settings.
Jan 15, 2009 | Olympus FE-310 Digital Camera
When takining photos all the shot recently appear with a blue tinge. Before taking a photo, the screen displays the following; 'P' left hand top right corner. light bulb left hand side and along the bottom...
You are in Program mode most likely, with some sort of white balance setting that is not sunlight. Go into menu and try to change back to auto mode,or reset all or default. Sometimes removing the battery for 12 hours gets it back into default mode. the HQ is just the resolution that it is shooting in.
Apr 22, 2008 | Cameras
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Canon PowerShot A95 Digital Camera Logo
227 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
