Question about Antec SP450 450W SmartPower ATX 2.0 20/24 Pin ATX Connector Power Supply (SP450) (PS450ANSP450) Power Supply
DOA After 2 years of good service, the Sonata PS (450W SmartPower) has apparently died. Either that, or the MB died. At any rate, unplugging each item (drives, cards, memory) in a systematic way does not restore power. Swapping cords, and using a different power out does not solve the problem. The machine behave as if it is not plugged in (no fans, beeps or anything else).
  • sjrepsher Oct 21, 2008
    Similar problem! after 2.5 years:
    I have the same case & sp 450 with an abit AW8 motherboard---
    - computer does not shutdown properly - the power simply turns off mid way through the shutdown process -
    - Sometimes the computer tries turn back on by it self - to stop this I turned off the power switch on the power supply -
    - after this the computer does not want to restart -
    - Code progression display when trying to restart : 0.0. , 8.3. (quik flash), F._ , _1. then back to 0.0.
    - computer does start about 5% of the tries --- When it starts, everything runs fine
    - when started it will restart with no problems
    - if standby is selected, it turns off same as if shutdown is selected
    - tried resetting the CMOS - does not seem to have any effect on the start up process
    Please tell me if this is a MB problem & or provide suggestions.
    MB was purchased from Newegg on 4-15-06 : AW8 socket T (LGA 775) Intel 955X ATX Intel Motherboard
  • 2,794 Answers
You can try a different power supply and see if that works. If it still doesnt work, it's the motherboard.
Posted on Jul 19, 2008
  • 25 Answers
Sounds like you need a new power supply for your computer.
Hi...ihave antec sp-450 smart power and it have 2 fans.only one is working when i pluged it ...is it a problam or the ather fan starts to work later????
If the fan that is working is the outside fan on the power supply and if your case is well ventillated there wont be a problem. If not then buy a new power supply.
Jun 17, 2012 | Antec SP450 450W SmartPower ATX 2.0 20/24...
Main fan is off not warking
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Apr 25, 2011 | Antec SP450 450W SmartPower ATX 2.0 20/24...
Codegen 450x power output dies soon after turning on. is there a component that commonly causes this?
Mar 07, 2011 | Codegen (PS-450W) (PS450W) 450-Watt Power...
5 yr old Asus with antec 450 power supply has had NO issues ever. Now I need to turn the ps off and on 2 or 3 times before the start switch at the front of the comp will work.... once it boots up...
there are several filter capacitors inside the power supply that are defective and /or are changing value. this accounts for the high pitch squeel you are hearing...the only REAL way to test for these problems are with an esr meter or lcr bridge, but you can physically look at the capacitors and see if any of them are bulged up or leaking., my suggestion is to go to tigerdirect.com and get another 450W or better PS...they are pretty cheap there
Dec 27, 2010 | Antec SP450 450W SmartPower ATX 2.0 20/24...
Does Codegen PS-450W PSU have connector PCIexpres with 6 pins or less_ Thank You
from what i see, I dont see a pciexpress power connector and I read it does not have SLI capabilities. so I believe no is the answer, sorry.
Features
Connectors 1 x Main connector (20+4 pin)
1 x 12V (P4) (8 pin)
7 x peripheral
1 x SATA
2 x Floppy
Aug 12, 2010 | Codegen (PS-450W) (PS450W) 450-Watt Power...
My computer just died the morning. I removed the
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
gray- power good(+5v)
purple- stand by (+5v)
disconnect smps from motherboard give the power to smps and short green and black wires and measure the above voltages
Mar 19, 2010 | Antec SmartPower 2 SP400 400-Watt Power...
GT4022 Gateway FIC KTBC51G Motherboard died
How did you determine that the MB was dead? Do you know how to use a post card and do you have one? How old is your computer and is it worth it to replace the MB? It is usually fairly easy to find a replacement MB on Ebay. Although, today desktops are so inexpensive that you may want to try that route. If you do replace the MB make sure that your power supply is adequate. We build systems every day and we never use less than 450W. If you do decide to replace the MB email me if you run into any problems and I'll see if I can assist you.
Jul 30, 2009 | Gateway GT4022 PC Desktop
Connecting my PSU to my Motherboard
The bare essentials to start a computer are PSU, Motherboard, CPU, RAM and Video.
Its possible the PSU arrived DOA. Though I've only had 2 DOA PSU's in the 15 years I've been building custom computers.
Hope this helps.
Mary
May 21, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Antec SP450 450W SmartPower ATX 2.0 20/24 Pin ATX Connector Power Supply (SP450) (PS450ANSP450) Power Supply Logo
354 people viewed this question
Top Antec Computers & Internet Experts
Dimitar Todorov
Julie Endres
Wahs Team
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
