Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Mixer bowl is stuck can not remove
5 QT kitchen artisan KSM150PSER
  • 6 more comments
  • jlsb Sep 08, 2008
    The same thing happend to mine yesterday. I'm thinking of putting grease, like maybe shortening.... to make it easier to dislodge.
  • Anonymous Nov 26, 2008
    I cannot dislodge the bowl. I feel like taking a rolling pin to it. Here I am ready to make pie dough for Thanksgiving and I can't do it with this expensive piece of junk.
  • ChristopherT Nov 27, 2008
    We're mixing sweet potatos and our bowl is stuck too. I've wrapped a hammer in a wash cloth and tried hammering it out to no avail.
  • Anonymous Jan 13, 2009
    This happened to me twice in recent weeks. It was just by pure luck that I managed to free the bowl. The cause of this problem may be explained in the following review I just read on an internet blog:
    It's still a great mixer but I was disappointed as the quality control is not what it used to be...apparently when they were making the bowl there was some flaw in machining the bottom threads of the bowl that screws into the base plate. Everytime I've used it, the only way to keep the bowl from becoming so tightly jammed into the base plate that it impossible for me to remove the bowl myself. I had never had this problem before and then a friend who had to help me remove the bowl pointed out that the threads on either the bowl or the base plate were defective.
    UPDATE: I called KitchenAid Customer Service and they promptly sent a replacement for the bottom plate...glad I bought KitchenAid because while there was a mistake in machining this item they were really "on the ball" in terms of getting it fixed. Works GREAT now.
  • TheNeedlewom Jan 28, 2009
    Unable to resist the yellow KitchenAid mixer because it matches my new cabinets, I bought the Artisan model. In over 48 years of marriage, I have enjoyed 3 other KitchenAids, all with bowls that lift. Never have I had a problem with a KitchenAid - until now. The bowl either gets stuck or proves difficult to remove. A new base has not helped. The suggestion to place ice cubes in the bowl makes little sense since the idea is to be able to remove the contents of the bowl. Do we really need to keep a hammer in our utensil drawer? Isn't the idea of these appliances to simplify the preparation of our meals?
  • Anonymous Feb 01, 2009
    When my bowl became totally jammed, I went right to the big guns and sprayed a little WD40 at the base/bowl juncture and waited a few minutes. Popped right out!
  • Anonymous Feb 06, 2009
    I got this as a wedding gift and want to make cookies for my sister's baby shower, can't do it! This is ridiculous!!!
  • monopril
    monopril Aug 20, 2012
    Marsha from SC OMG my mixing bowl got stuck with the dough in it. I called Kitchen Aid and they told me to wrap base with warm towel for 10 minutes. It did not work!!!
I found a solution at kitchenaid.com. It says the bowl locks in the same direction as the rotating mixer moves, so slap the bowl with your hand a few times in the opposite direction, and then take vegetable oil and using a cotton swab line the groove of the bowl. Let it soak a bit, and then slap the bowl again and push it hard counterclockwise.
Posted on Nov 27, 2008
  • Jan Rutte
    Jan Rutte Sep 22, 2014
    I tried several solutions that didn't work but this one worked like a charm!!!
I sprayed nonstick spray around the base, left it for a couple minutes, then the bowl came off very easily.
Posted on Jan 12, 2009
Try this solution I've read somewhere online. It worked for me, I hope it does for you too.
Put ice cubes in the mixing bowl. The cold will make the bowl contract a bit. Then with your palm, tap the underside of the bowl (in a clockwise direction) a couple of times to help dislodge it.
Posted on Nov 30, 2008
I used olive oil on the base (between the bowl and the machine) and took a hammer and gently tapped it on the bottom of the handle counterclockwise. It didn't dent the handle and the bowl pops right out.
Posted on Dec 14, 2008
I used for 1st time. My cookie dough turned black. Also now have large bump up in middle of bowl.
Take it back to the shop, it sounds like head height adjustment is incorrect from new. I hope you didn't tighten a screw by the inside of the hinge that looked loose. that's your head height adjustment. There is a cone shape at the bottom of the bowl if that's what you think is the bump.
Dec 11, 2015 | KitchenAid Kitchen Aid KSM150PSPK - 5-qt...
Took brushes out of artisan KSM150pser and put back in and mixer won,t start.
Yes there is a secret, the brushes are keyed and you need to line up the cut off corner with the blocker deep inside the brush holder, use a torch.
Mar 19, 2015 | Food Mixers
Kitchenaid artisan mixer locking switch only locks 3/4 the way and motor head bounces when mixing dough, although is still locked down.
Make sure that the hinge pin is locked up firmly with the grub screw that is accessed with machine upside down on a towel. It is right up the middle of the pedestal. Next fit bowl & flat paddle and adjust head height with the screw that you can see when the head is raised up. The screw is right in by the middle of the hinge for the head unit. Screw it in (clockwise) a bit to lower and anti clockwise to raise. You want to screw it in enough to just hear the paddle tinging on the bowl and then anti clockwise the screw so it just clears. 1/4 turn from tinging is roughly it. If the head is still not locking down you may need to run a rat tail file through the locking slot to allow the lock better engagement. This is a last resort, if you file too much it is permanent and cannot be reversed so don't do it until everything else has been done properly. It's not a big job for your local Kitchen Aid service agent to sort out for you.
Dec 29, 2014 | KitchenAid Kitcheaid 5 Qt. Artisan Stand...
The screw underneath the head of my kitchen aid mixer is tight, but the head is still wobbling. It isn't a beater adjustment--I already tried that. The head of the mixer is tilted forward a bit--in
When you have the head lifted up the screw you can see in there from the front in the middle by the hinge is the head height adjuster. You need to set the height correctly now so that FLAT PADDLE just clears the bowl. Unscrew it anti clockwise to raise the head. Once that is done turn the machine upside down on a towel and check that the locking screw on the hinge pin is tight, it\'s right up inside the pedestal.
Aug 08, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
Why kitchen aid mixer wont turn on
Any number of reasons such as:
Bad electric cord
Bad brush or brushes
Bad armature or stator
Control plate broken
You need the Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
While this manual does not cover the Artisan specifically, the procedures do apply.
Jun 04, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Where would I find a bowl lift replacement mechanism for a kitchenaid 5 qt mixer model K5SSWW.I have a kitchenaid 5 qt mixer model K5SSWW. I need a bowl lift mechanism replacement part but can't find this...
The model number seems to be valid-but given the age of the unit few parts are readily available. You might want to try eBay or a used appliance store (or even Goodwill) to find a donor machine.
May 02, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid artisan mixer is loose and shaking
This could be the pivot rod between the head and the column being loose and out of place. Or it could be the hook activated by the lock lever not engaging properly. See the following Service Manual:
Mar 30, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
It doesn't start
Check the fuse, and the bowl should be in place
Mar 26, 2013 | KitchenAid Artisan Ksm150pser 325 Watts...
Need bowl and mixer attachments for Kitchen Aid Artisan Mixer
We've found most all accessories at any place that sells the mixer. Bowls, beaters, meat grinders, pasta makers, etc.
Jan 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid stopped working Modle KSM150PSER
Hi Phyllis. Unplug the mixer, lay it down on one side and look for the pin that holds the planetary shaft in place next to (where you attach beater). The pin may have worked itself loose. If this pin is not all the way through it's opening, the shaft will not turn the planetary unit. Hopefully the pin did not come all the way out and you can tap it back in. If the pin is gone, It's in one of your cookies and hopfully you'll find it before anybody else does. Hope this helps. Ricardok45.
Dec 17, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
5,250 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
