Question about Pioneer Televison & Video
Hi just bought an Apple Tv Box to connect to my Pioneer PDP 434HD Tv via the HDMI port on the receiver. No picture and hen I go into HDMI setup in the TV menu it is greyed out. How do I enable it ?
  • Pioneer Master
  • 19,396 Answers
Pioneer elite. get CEC100 error. which says that "the device cannot be operated. please check the connection"
I have a Pioneer PDP-LX5090, Kuro Flatscreen TV, connected via HDMI4 on a Pioneer AV-receiver VSX-LX60.
By connection a Chrome cast on one of the HDMI ports of the AV-receiver I got the same CEC100 error with the same message "device cannot be operated. please check the connection". By disconnection the Chromecast from the USB current feed, the problem dissapeared. Hope this can help you.
Jul 01, 2017 | Pioneer Televison & Video
I am trying to connect ps3. (bought may 2012 with uncharted 3). To my denon 2313 via hdmi. No video at all or sound? Please help
You need to tell the PS3 to use the HDMI cable output. To test have you tried connecting the PS3 directly to the TV. Once you have that working then add in the AVR.
Jan 19, 2013 | Denon AVR-2313CI
PDP 435HDG HDMI selection
Do a factory reset to this set and proceed. Refer its user manual for details.
Jun 05, 2012 | Pioneer Pdp-4360hd 43 Purevision...
I am trying to connect my new apple tv to my panasonic bt205 ht and then to my samsung tv. As I have only i HDMI socket in my Ht I bought a HDMI splitter. This doesn't seen to work. If I connect the...
The BT205 only has a HDMI Out so you need to connect both your BT205 and Apple TV to your TV either directly or through your splitter (depending how many HDMI Inputs your TV has).
You then need to connect either the Digital or Analogue Audio Port from your Apple TV to your BT205 and select the Audio Output from your BT205 as detailed on Page 27 of the manualat the link below.
http://tda.panasonic-europe-service.com/docs/2z4e3b157ez3z2a0dbz656ez706466z21z3703f025f4fa80ffdb9e5a7957895ca96b778f45/tsn2/data/ALL/SCBT205/OI/812908/rqt9445-b.pdf
This will give you the picture from your Apple TV to your TV via the HDMI and the Apple TV sound to your BT205 via the Audio Port.
Aug 04, 2011 | Audio Players & Recorders
My tv does not have an hdmi port. I have a device I'd like to import (Apple TV) I'd like to connect. It has an hdmi input for connection to the TV. Is there something I can do to be able to connect to a...
There are adaptors available to convert HDMI signal to other standards. You will lose quality in picture and sound but you can get HDMI to RCA converter. If your TV has a DVI is still a digital input so will yield better quality.
Jan 14, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
(Pioneer PDP-4340HD Plasma with PDP-R04U Receiver) My HDMI input works, however having a computer or Xbox connected via HDMI I do not have the optical output signal thus I can not hear audio through my...
I don't have a direct solution but I am having the same problem when connecting (1) my Apple TV (2) my Blu-Ray player, etc. via HDMI. I also have a digital camera that puts out HDMI, and when I hook it up, I get the same story -- video only, no sound through the optical digital output of the TV receiver.
I am guessing that the HDMI inputs were an afterthought on this model, especially since the printed manual doesn't even show or mention the HDMI inputs at all! So my guess is that the TV's receiver does not convert the sound from the HDMI to the optical digital output. It does, however, send the amplified HDMI sound to the stereo speaker outputs on the monitor. It appears that only the digital tuner's 5.1 sound comes out on the optical digital output.
This is what I have observed, for what it's worth.
Nov 04, 2010 | Televison & Video
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Can't get full streaming to pioneer plasma from mac book air
Hi
Do you recall when Steve Jobs introduced a little white box called the Apple TV which allowed his products, both Software like TV shows and films from iTunes, to connect to digital TV displays?
Within that little box was the solution to problems their engineers foresaw.
You can connect your mac book to the Apple TV box and achieve the advantage of components therein that solve the problem you have by virtue of disk swapping on the 40GB or 160GB drive.
If you don't want to purchase an Apple TV and subscribe to the services for any reason, you should, if available disk space is available on your macbook, increase your swap space on the drive you have or on external drives so as to accomplish flawless streaming.
If you need help on that, let me know.
Mar 28, 2009 | Pioneer PureVision PDP-503HDE 50 in....
Televison & Video Logo
415 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
