Question about GE Spacemaker JVM1640SJ Microwave Oven
Turn Table wont turn
Hi: I have a GE OTR microwave oven and recently the turn table stopped turning. I have checked to be sure that it is turned on. Any suggestions short of calling a repair service?
Thanks in advance for any assistance you can give me with this problem.
Mary
  • irisheyes86 Jul 20, 2008
    Thanks drcool:
    We tested the motor and it was fine. Came to find that the little plastic piece (coupler) in the center was broken. Thank goodness it was an easy fix! Thanks for your quick reply, it was greatly appreciated.
    Mary
  • 958 Answers
If you can check the turn table motor for resistance. 90 percent would be a broken motor which you could replace. just look for the motor at the bottom of the microwave and race the wire back to the pc board.
i hope i was able to help..
pls rate me
tnx,
drcool
Posted on Jul 19, 2008
Turn table will not turn
I'd check to see if the turntable motor has continuity. If it does, check to see if 120 volts is being supplied to it. If both are o.k., then the motor has probably bound-up in some way internally. There's also the possibility that it has mechanically become detached from the hub that turns the glass tray.
May 06, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
My food no longer rotates while cooking,and it makes a clicking noise.
this is usually a bad turn table motor. if you remove the screws out of the bottom of the otr(over the range) it will hinge down and back and you will see the motor in the middle of the otr. your local parts house should have this item in stock or be able to order it for you
Apr 24, 2010 | GE Advantium 120 Convection/Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven model #JVm1850wd002 turn table does not operate or
Take off the case. You'll see two prongs on the door. If they are out of adjustment.And don't trip the contacts. nothing will work. Theres nothing mech on the turntable, the micowaves make it turn. Just make sure it turns freely,and is clean.
Dec 29, 2008 | GE Microwave Ovens
GE Spacesaver MicroWave
have you checked to be sure there is nothing stuck in the opening where the turn table sets, my daughter and husbannd bought one and hd a small piece of hard pllastic stuck in the opening. that cost them $85.00 to have a service tech find!
Oct 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker making odd noise
We are having the same problem with our XL1400. I suspect it has something to do with the turn table but don't know for sure. We would be willing to disconnect the turn table...anything to stop the noise but don't know how.
Mar 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
195 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
