Need BIOS update to install more RAM
Don't know if you got my reply to your answer, so I'll try again. I had already gone to the ASUS website but couldn't be sure exactly which BIOS update I needed and was afraid to install the wrong one and not be able to recover the old one. I also tried to install just one of the two 256MB RAM cards I ordered, but that didn't work either. Any other thoughts?
  • ferganeeeeee Jan 14, 2009
    i need to update my bios
    Scholar:
  • 125 Answers
Since it is an HP product (did not realize before) try this BIOS:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=59615&lang=en
There is some more info about your board here:
I beleive that most flashing utilities allow you to save your old BIOS, just in case. This feature was for incompatabilities mostly, since you still need a working BIOS to restore an old one.
Still, I am puzzled that you need to flash it just for memory. I assume you have the correct memory, this one takes 100MHZ DIMMS. The specs page does not state max module size, but I am sure 256M within range. Perhaps there are some settings in the BIOS to play with.
Posted on Jul 21, 2008
Asus eee pc bios in this system is not fully acpi compliant
These errors can be misleading. Try setting the BIOS to default.
Remove all USB attached devices.
Test one DIMM at time. One slot at a time. To eliminate possible bad RAM. Unplug PC. Opening case. Remove all RAM. Use static precautions!
Re-install Windows. Clean install works best. All data will be lost.
Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 09, 2012 | ASUS Eee PC 1015PEB 10.1 Netbook 1.66GHz...
The Hard Drive keeps making a bleeping noise and it is not letting me acces it, what could the possible problem be?
you need to know computer BIOS to know message from beeping code. when u know the BIOS product then listen the beep (short or long, how many beep, etc). after u recognize the beep pattern, try to 'google' it with your BIOS product and beep status. or u can reply from this answer, maybe i can help.
tips: a lot of problem that computer cannot run and makes beep sound is that RAM not correctly installed, try remove it and put it in again in another RAM slot. if u use external VGA, try to remove it and put it in again.
hope this useful, regards.
Aug 16, 2011 | Computers & Internet
I have an asus pn5sli mobo with 8 gig ram, nvidia 9800gt gpu,running windows 7 and am having crash issues.can you update bios using a usb as I have no 1.44 floppy installed and can you increase ram voltage...
Hello download your files here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5NSLI/#download
Download asus update in the utility for 64 bit system
Next download the latest bios
Please unzip the files before you install.
Install asus update and select update bios from file.
This can be done while the system is running.
Select the bios file you have downloaded
and the program does the rest.
Remember to download the right bios.Flashing the bios with a wrong file will damage the mainboard !!!!!!!!!!!!
And you need to set up bios when the job is done (the boot sequence)
Good luck
Dec 17, 2010 | ASUS P5NSLI (0610839134670) Motherboard
ASUS P5VD2-MX SE recognizes only up to 2500MB RAM
Actually you are doing better than you think, According to your MB specs it is only supposed to hold a max of 2GB (1GB per slot). The updated BIOS may be allowing for the additional 500MB.
If you would like to verify, here is a link to the manual for your MB:
P5VD2-MX SE Manual
See page viii.
Thanks for using Fixya.
Wayne
Sep 09, 2009 | ASUS P5VD2-MX SE Motherboard
Problem with Shutdown
try microsoft/windows update, its on the start menu
reply if you still need help have a good day please rate bama46
Aug 22, 2009 | ASUS P5QL PRO Motherboard
Asus P5VDC-TVM Bios update
Please do not update BIOS unnecessarily. Only when you face problems and the error message request for BIOS update only then do so. On asus site enter all the required details & try, but my advice is to leave it alone if its in working condition....sodeep
Mar 20, 2009 | ASUS Computers & Internet
Question from docustor re:ASUS Intel 810 Chipset MEW-AM
the intel 810 chipset requires very specifically made 256meg sticks to support that much memory. the 256 meg standard has changed, and the 810 wont support the ram unless it is made by the old specs. smaller ram sticks such as 64 and 128 will not have this problem.
Jul 19, 2008 | ASUS Intel 810 Chipset MEW-AM Motherboard
Updating BIOS for ASUS CUW-AM/MEW-AM Motherboard
Try locating your bios etc. on asus's website:
http://support.asus.com/download/download.aspx?SLanguage=en-us
128 to 256 seems like you should not need an update. Are you putting in a second 128 stick, or replacing a 128 with a 256?
Jul 18, 2008 | ASUS Intel 810 Chipset MEW-AM Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
1,069 people viewed this question
David Payne
David Payne
