Question about AudioTrak MAYA44 MKII Sound Card
Trouble installing a maya44 usb audio device to my BPM studio software
Hi i have a problem trying to installing this device in to my BPM software i have windows vista i think this is the problem but i don't know for sure.. if u can help me out with this problem i'll app...............thankkkksssssssssss I've tried their website to download compatible drivers for windows vista but still it doesnt wana work.
  • 304 Answers
Did you disable the onboard sound device using the device manager. You can't have 2 sound devices active at the same time or it will cause conflicts. I'm pretty sure this is your problem, but if not feel free to contact me and I will help you diagnose you problem deeper.
George
Posted on Jul 19, 2008
  • George Kohler
    George Kohler Jul 21, 2008
    Also, There are several other things you can try:
    Right click and Install your driver as administrator, If that does not work right click on the driver install and select compatibility and choose Run in XP compatibility Mode and install as administrator.
    I'm quite sure the problem is that you did not disable the on board audio in the device manager though. This will cause that problem every time. And as far as Vista goes I have been running Vista Ultimate for 10 months now without a single hitch. As long as you run it on good equipment It is far superior. I was running it on my 2.0Ghz Core duo laptop most of the time and last month I picked up a 2.5Ghz 3gb HP laptop and I have never seen a more powerful secure system. With the bit locker software my 250 gig HD is completely encrypted and secure. It does stink if you are trying to run it on outdated equipment not designed to handle it. A good analogy comparing a VolksWagon Rabbit to a Ferari. Some of the people will always like a VolksWagon because it's slow and safe and it get better gas mileage. I just can't lean that way when a pentium 4 3.0ghz XP takes 2 hours to transcode the data streams and burn a dvd while a Quad Core 6600 Vista Ultimate machine only takes 15 minutes. It all depends on how much processing you do and what your time is worth to you.
    Just a rant,
    George
  • George Kohler
    George Kohler Jul 23, 2008
    Please log in and rate this comment fixya if it helped you resolve your problem. If it did not send me an E-mail with
    your phone number to geokohler@gmail.com And I will help you fix your problem. Do not rate the problem until We
    have it fixed.
    Thank you,
    George
    Ps. This is totally free or charge to you. I even pay for the call.
    President:
  • 778 Answers
XP works GREAT, and Vista still has problems. So if you want a reliable compatible OS, switch back to XP and next year Vista should be good to go. MS is notorious for marketing Operating Systems before they are fully compatible. So, if you like problems and waiting for solutions, stick with Vista as it may work correctly someday soon.
What cable would I need to connect the audio output of a Yamaha Claviola to a Mac running Garage Band?
in order to make a good connection with digital audio i recommend using an audio interface i personally use a maya44 usb.
Feb 08, 2011 | Yamaha Music
Mini DV connected to Dell PC by 1394 cable
Open DISK MANAGEMENT,see if there is a Drive letter conflict (USUALLY with Mapped drive)
Jun 26, 2008 | Panasonic NV-GS4B Mini DV Digital...
My oxygen 49 3rd generation (m-audio) midi keyboard just stopped working for me. Ive tried changing the usb lead, and I've tried it on a different computer, and it still doesn't work. I have a macbook pro,...
If the keyboard is lighting up, there is a 90% chance the problem is in the software in your MAC.
Hint: Software "breaks" easier than the hardware !!!
Re-install your software as a first step.
Sep 12, 2010 | M-Audio Oxygen 49 USB Midi Controller
Driver installation problem
Some computer firewire interface's don't work very well under Windows... However...
Make sure you follow the installation directions to the letter... especially in regard to whether the cable is plugged in while installing...
Also you MIGHT try installing the software in SAFE MODE.
Then in the audio editing software you often have to configure the audio in/out device.
This can realy be frustrating... I just fought a UA 25EX to get it to work and the problem was an incorrect switch to the sample rate.
May 24, 2010 | Behringer FCA202 - FireWire Audio...
Lexicon Omega will not play any sound on Windows XP
one of several install steps (the steps seem to vary depending on which manual you can find) mention checking your sound device setup in control panel. ON one machine I installed the sound devices were not affeted. On a 2nd PC they were changed from drivers installed with PC to the Lambda driver
Win XP settings->control panel->Sounds and Audio Devices then select Audio tab. Make sure the three areas are set up to use your PC's default drivers and not lambda's.
You may need to verify this again when reconnecting the Lambda USB cable. Sort of new but ran into this "issue" as well.
Found info in Lambda Studio Software Installation Guide I downloaded, step B following driver install.
Nov 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Finding bpm studio crack/patch
To be honest BPM Studio aint worth Cracking anyway, it's **** in comparison to other DJ Software such as Virtual DJ.
Above all, I'd be very careful about what you ask for on sites such as this, as your basically asking someone to willingly participate in Software Piracy. Above that, Alcatech's BPM Studio uses Tight Anti-Cracking Procedures, and a cracked copy would be diabaled within days anyway.
Best off searching on Google using the following Keywords :
Freeware DJ Software Downloads
You'll get some decent full version / no limitation software that way.
Nov 16, 2008 | Computers & Internet
Download the updated driver for Vista from this link: http://download.esi-audio.com/?w=esi&p=40&g=2&l=en
Hope this helps and if does, please vote.
Thanks!
May 01, 2008 | AudioTrak MAYA 44 USB External Sound...
Maya44 poor sound quality
Check the maya graphics card audio settings. there may be some improper audio setup. the Maya 44 card audio codec and filters are not supported by your OS. Your system configuration is good. there may not be any problem with Pc compatibility. only because OS audio codecs. try dowloading codecss for this audio rendering device
Dec 17, 2007 | AudioTrak MAYA44 MKII Sound Card
USB Midi Controller
the 'Add New Hardware Wizard' and force it to install the non-certified M-Audio drivers that were supposedly installed when running the M-Audio installer. (Skip internet search, and browse to M-Audio folder in Program files, it will eventually find them.) There are two M-Audio USB drivers that need to be 'forced' via New Hardware Wizard. But Windows thinks its drivers are a better match and even though 'device is working properly' it doesn't get recognized in your software. replaced them with the 2 USB ones from M-Audio, DAW finally recognized the keyboard. I even went through regedit to clean up all the M-Audio stuff so I could get a fresh install.
Good Luck you can do this /Have a great Sunday and a safe one.
Dec 02, 2007 | Acer TravelMate TM3012WTMi (LXTAT06045) PC...
AudioTrak MAYA44 MKII Sound Card Logo
214 people viewed this question
Top AudioTrak Computers & Internet Experts
David Payne
David Payne
Are you an AudioTrak Computer and Internet Expert? Answer questions, earn points and help others
