Trying to connect my lapton to router, it asks for a wepkey or a wpa key.
    President:
  • 778 Answers
If it's a router that you have physical access to, you can use a pen to reset the router to default ( unsecured ), and address the router and reset a password.
Posted on Jul 19, 2008
Keeps dropping wireless WPA-Personal internet connection
If it is not a router problem then you could try a wireless adaptor such as the Lapton N300 USB Adapter. This adapter will connect to all OS including Linux. $20 Max. I had a problem at home where a laptop would not connect at all and this adapter did the job. Maybe worth a try
Oct 28, 2013 | Microsoft Windows XP Home Edition
How do I find my Wpa Key Number
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 07, 2012 | D-Link (DI-711) Router
Trying to get my playstation 3 online but it asking for WPA KEY. I dont know what it is.
This key is the security phrase (or characters) that you have to write down in order to connect the playstation with the Wireless Network (Wi-Fi) at the place you are. Either you can ask for this WPA KEY the from the person that set up the Wi-Fi or you can use a pc already connected at this router in order to go to the router's settings page / Wi-Fi / security and read the WPA KEY by yourself.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 13, 2011 | NetGear WGR614 Wireless Router
Whats a wpa key? I have tried connecting to my router on my wireless device and my wireless device ask's for a wpa key? is it the same as a lan key?
WPA <<===>> WIRELESS PROTECTED ACCESS
You need to use an Ethernet cable to connect a computer to the router, and then access the web-server inside the router, and then run the "Wireless Networking Setup Wizard". When you do, you will set:
* the SSID ("network name") -- pick anything you prefer
* the encryption-level (hint: use 'WPA')
* the password for the network -- pick anything you can remember
Then, from a wireless device, do a "View Available Wireless Networks".
Select the SSID, and enter the password, to make a connection.
Feb 01, 2011 | D-Link DIR-615 Wireless Router
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
The wepkey
The WEP key is assigned by the network admininstrator.If you are the one just log in in the router set up page and assign the WEP or WPA key.
. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Un checking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
Dec 18, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
How do I find the WPA key ?
If you are trying to connect the PSP through a network that belongs to you, then the network administrator is the person to ask for the WPA key.
The WPA is like a password. It protects the network from unauthorized access.
Jun 23, 2010 | NetGear WGR614 Wireless Router
Wepkey/wpa
wep key and the wpa pass phrase is a wireless security option in the wireless option you got it to protect the wireless connection and you have the wireless router or modem or access point in that option you got it for the wireless security.
May 12, 2009 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
