SOURCE: my 500W powered aspire alienware case
Hi, this can be a common problem, get a small set of side cutters and gently split the plugs to seperate each one. then plug the 2 you need on to the board, turn them sideways so they do not interfere with each other. when pluged on the board you may need to swap them around till they work. Dont worry if you get them the wrong way around you will not do any harm. note there are no adaptors for these connections. Regards mistyman
SOURCE: connecting startup leads to ABIT NF7 motherboard
Below is a link to the manual for this motherboard, It should be able to show you where each of the leads on your dislocated panel wires go to.
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&category=5&subcategory=247&model=8&product_name=NF7
Hope this helps
Thanks
Dave
SOURCE: can not find location to plug in my case wire plugs on my mother
you will need to take out your motherboard manual and look thru it for the usb header and audio header for the correct pinout in order to plug those in
SOURCE: Case wiring
For the wires that comes in your CPU casing, mostly used for your front panels like power switch, hdd status, power led, etc. It is indicated on the pins itself so you might not be confused. there are some that comes for front panel USB. (with codes like vcc+ /- ,etc.). The best you can do is to read your Mainboard manual on where you place this pins.
