Question about ASUS Intel 810 Chipset MEW-AM Motherboard
Question from docustor re:ASUS Intel 810 Chipset MEW-AM
Thank you for your reply. I am trying to install 2 RAM cards, each with 256MB PC-100 DIMM, to total 512. I tried installing just one of them, but machine wouldn't boot. I also did go to ASUS website before I posted to FixYa, but could not definitely determine which BIOS update should be used, and I am afraid I'll disable my whole computer if I download the wrong BIOS since I am not very tech-savvy. When I was reviewing your answer at FixYa, there was a link that somehow got me to a phone number at ASUS tech support, so i can try to speak directly with someone there on Monday. Any other suggestions you have would be most appreciated. Direct email to me is docustor@yahoo.com.
Thanks--Steve
    Genius:
  • 1,066 Answers
The intel 810 chipset requires very specifically made 256meg sticks to support that much memory. the 256 meg standard has changed, and the 810 wont support the ram unless it is made by the old specs. smaller ram sticks such as 64 and 128 will not have this problem.
Posted on Mar 11, 2009
IBM instructions for installing memory modules is that they must be done sequentially starting at DIMM 1. When removing them to upgrade should I then remove DIMM 2 first, and then remove DIMM 1, and...
It shouldn't matter what order you remove and replace the RAM cards in. The instructions are saying to populate Slot 1, Slot 2, and then other slots in order; don't skip any slots, in other words.
Dec 31, 2010 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Sound Card Driver needed for Win XP runing on Intel 810 Board
hi im josh in cebu phils. it is very simple frnd. you try to install windoxs xp sp2 or sp3 so that you will not need to install driver for sound. or just get an update of your xp professional. good luck!
Feb 17, 2009 | ASUS Intel 810 Chipset P3W Motherboard
Installation problem
i think you are having problem with ram that you have not given here
Jan 19, 2009 | ASUS Intel 810 Chipset P3W Motherboard
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Ram gets detected only to half of the value specified
dear pradhan
your ram 256 but i think your ram memory shared with disply memory so . first restart your system and press DEL key untill u enter in bios setup.then go tothe advanced option and disable graphic memory then save settings and restart pc . your problem is solved.
Mar 18, 2008 | Intel SuperMicro SUPER Motherboard - 810...
Cant insall new graphics card
the graphic card is a plug and play device meaning as you install it, it is giving its resource and it starts working but you install yours and the motherboard beeps means
1. there was a change in the CMOS configuration which should not occur
2. the CMOS utility did not identify any graphic device
i think your graphic device is questionable it could not be good is the word.
UZOWUANYA
e-mail:uzowuanya@yahoo.ca
Feb 14, 2008 | ASUS Intel 810 Chipset MEW-AM Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Motherboard is dead
remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
May 31, 2007 | Intel SuperMicro SUPER Motherboard - 810...
ASUS Intel 810 Chipset MEW-AM Motherboard Logo
176 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
