Question about Epson Stylus Photo R300 InkJet Printer
Images printing as negatives
Our printer has started printing the images as negatives.  It prints this way directly from the memory card and from programs.  We have cleaned the nozzles but aside from that we're at a loss. Thank you for your consideration.
  • 3,940 Answers
In the printer setup (Click File Print) there may be an option in the advanced printer setting to invert the colors or print a negative. You need to uncheck/disable this option
Posted on Jul 19, 2008
How do I print pictures from my camera on the computer(pictbridge)?
The camera compares its PictBridge functions to the functions of the printer. The camera then displays the supported functions on menus on the LCD screen or in the viewfinder.
PictBridge print options
Once a PictBridge digital camera is connected to a compliant printer, print options appear on the camera LCD. The camera menu system is used to make settings such as print size, layout, media type and date.
You can print a single image displayed on the camera, print two or more images or print all images on the memory card. You can print part of an image by first cropping it within the camera and even create index prints, also known as contact sheets.
Print sizes and PictBridge
Not all PictBridge digital cameras let you select all available prints sizes, such as 13×19? if you have a wide format printer. If the printer has a memory card slot, use it and larger size prints should be available.
Is your device PictBridge compatible?
To find out if a camera or printer is PictBridge compatible, look for the PictBridge logo on the packaging or check the manual for specifications. If still unsure, call the manufacturer!
Jan 13, 2011 | Cameras
Can't remove memory card from printer
hi
  • Ensure the MP970 is connected to a working electrical outlet. Turn the printer on by pressing and releasing the power button located on the upper left hand side of the control panel.
  • Step 2 Select the memory card you wish to use. Insert the memory card into an appropriate adapter if it requires one. Open the Card Slot Cover, located on the right hand side of the printer, by pulling the door out and toward the center of the printer.
  • Step 3 Insert the memory card into the appropriate card slot with the label side facing up. Confirm the Access Lamp is lighted. Close the card slot cover.
  • Step 4 Check the "Select and Print" option on the display screen. Select the "Okay" option.
  • Step 5 Load your preferred print media into the printer. Confirm Paper Source, Paper Size and Media type. Select the "Okay" option. Select the "Next" option. Select the "Okay" option to access the images on your memory card.
  • Step 6 Press the Left or Right Arrow buttons to select the image you wish to print. Press the + or – button to determine the number of copies of this image you wish to print. Select the "Okay" option.
  • Step 7 Confirm your print instructions. Select the Print option to being printing your photos.
  • Jul 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    I would like to know if its possible to hook a camera up to the printer for direct printing without using memory cards
    if the camera have memory and you saved the images on the camera yes if not impossible memory card is required since your images are there.
    Jun 25, 2010 | Sony SnapLab UP-CR10L Digital Photo...
    C6180 printing slow
    This could be from the image you are printing. If you are printing from a computer or memory card, the dpi (dots per inch) may be higher than some.Standard printing is typically 400dpi, and you can change the settings on your computer or the printer directly. Memory cards and some photos from your computer may be 600dpi and will likely take much longer to print since there is more "color information" that it is trying to fill.
    Let me know if this helps.
    Jan 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Ink not printing the same image quality that is on computer
    Issue When printing directly from a memory card, the printouts have an abnormally high red tone.
    NOTE: This does not affect the prints that were originally sent from the computer. Solution Press the Photo Fix button to turn off the Photo Fix feature before printing from a memory card. Cause The Photo Fix feature was originally designed to reduce/enhance printed pictures by making colors more vibrant. However, it can also have a side-effect to make some prints have more red tone than desired. In the HP Photosmart D7100 series printer, this feature is “ON” by default.
    Dec 15, 2008 | HP Photosmart D7160 InkJet Printer
    Camera wont transfer images to laptop
    If the camera displays "Communication Error," when trying to download images the main cause for this error is that there are more than 1000 images stored on the memory card. It is recommended if there are more than 1000 images on the memory card, that you use a card reader to acquire the images, or to delete images off of the memory so that there are less than 1000 images to download from the memory card.
    If this is not the case, there are not 1000 or more images on the memory card, try reconnecting the camera to abnother port on the computer, try another cable or another computer. This error can also display when connecting to a direct print printer. Please check with the printer manufacturer for more information on this error.
    Sep 02, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
    Print photos from videos camera
    The easiest way to do this would be to print the images directly from the memory card. you have not given your camera model but most of the Sony models use the Sony Memory Stick which can be inserted directly into your RX620 From here printing the images is fairly straight forward and explained fully in the users guide which you can find here -> http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=nKGrQtfEm6nLfXnUdNyU002F59t+NsSC4Fli&tc=5#10
    Aug 24, 2007 | Epson RX620 All-In-One InkJet Photo...
    Can I print images directly on printers capable of card direct printing via the Compact Flash in which images captured with the camera are saved?
    In general, you can print the images captured with the camera directly via Compact Flash card on any printer specified to accept Compact Flash type I and II. Please contact manufacturer of the printer for technical details.
    Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
    Exif Print or PIM Print feature
    The printing information that is included as part of the Exif 2.2 header in the JPEG file, is read and used by a Print Image Matching enabled printer. If you have a compatible printer that has a built in media slot, you can insert the digital camera’s memory card into a card reader and then into a printer’s media slot. If you do not have a printer that accepts a card directly, you can use a plug-in for a graphics program such as Adobe PhotoShop 7.0, to utilize this information. CAMEDIA Master 4.03 and above supports Exif Print and PIM.
    Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
    Epson Stylus Photo R300 InkJet Printer Logo
    214 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
