Question about Canon Rebel XT / EOS 350D Digital Camera
Help, I can't upload my pic's to my computer, I am using a port that worked
But now when I turn on the camera, the camera sayas BUSY (flashing), I can't get it to clear, what am I doing wrong.?????
  • 797 Answers
If you have a SD card, or any other in fact, you can get a card reader/writer at most electronics stores. This will enable you to use a card reader instead of using the camera to upload pictures.
I use a card reader all the time, and never (almost never) use a usb connecting cable to the camera to upload the pictures.
One problem which can arise is that the camera may have internal pictures taken with no card. If this is the case, you can in most cameras, copy from the internal memory to the memory card. I realize that there are digital cameras which have no way to record to internal memory, only on the memory card whether that is a SD or some other kind.
As to your direct problem. Try to reset ALL in the internal menu.
Posted on Jul 19, 2008
My Canon Rebel XT will not upload pics to computer. I have to connect camera to pc with usb port because I can not take card out due to pins have been bent and the card will not go back in easy. When I...
Try resetting the camera in the menu. If that still doesn't work there might an issue with your USB port and/or Main PCB. Contact a Canon authorized service center for assistance.
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
Jul 05, 2011 | Cameras
Camera or software froze up when uploading to computer
The warning about taking the memory card out while it says busy is to prevent corrupting the flash card during a write.  Give you were just reading the data, you should be OK, unless it was deleting the files as they were uploaded.  In any case, you will most likely need to remove the battery.  There may also be a small button battery that will need to be removed as well that is used to maintain the time.  I would turn off the camera, remove the memory card, remove the battery, put the battery back in (without memory card).  If you still have the problem try removing the button battery (I am assuming there should be a holder for one somewhere on the camera body).
Good luck, report back if this works or not.
Apr 25, 2009 | Canon EOS-20D Digital Camera with 17-85mm...
Busy when i use the flash.
The capacitor in the flash circuitry needs to be charged to a before the flash can be fired. This chargeing time is termed as flash recycle time and duriing this window the camera wilkl show that it is 'BUSY'.
Mar 23, 2009 | Canon EOS Rebel XSi Digital Camera
Can't upload pics to my computer
Try it in a dfferent USB port. The port your are using might be bad.
Mar 09, 2009 | Fuji Finepix Z20fd Digital Camera
My canon Rebel XTi keeps flashing busy and won't let me take a picture
I just called Canon because I was having the same problem. They suggested putting the camera in the sports mode. The reason it flashes busy is because there is a buffer period after taking pictures where the camera needs to store the information to the disk or if using a flash, then the flash needs to recharge. If you have plenty of natural light, then the full auto (the green square) mode can be selected because the flash won't have to recharge. If you are using the portait mode, then you will have to wait for the buffer period for the flash to recharge and the information to be stored to the disk.
Jul 21, 2008 | Cameras
Camera is busy or not connected
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 23, 2008 | Fuji FinePix A500 Digital Camera
Camera won't let me upload!
try useing it on another computer you dont have to install sony software to use the camera on another computer if it dose work that tells you that its prob your USB port.
Feb 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Busy message keeps flashing...wont upload photos
I posted with the same problem. I was reading the software guide that came with my camera. I ended up going to the menu on the camera and setting the camera's communication. It worked! I can now upload my pictures to my computer again.
Feb 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt
If you are using the camera software then remove it and Windows do the Work. If are sill having trouble, Then invest in a USB card reader.
Apr 23, 2007 | Canon Rebel XT / EOS 350D Digital Camera
How old is the camera? Still under warranty? contact Canon customer support
Feb 12, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
141 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
