1993 Chevrolet Corvette Logo
Tommy Theodore Posted on Jul 19, 2008
1993 corvette power seat failure
My power seats stopped working
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1346
Points
MY POWER SEATS WILL GO UP & DOWN AND WILL TILT FORWARD & BACKWARDS BUT WILL NOT GO FORWARD OR BACKWARDS. IT JUST MAKES A HUMMING SOUND WHEN TRYING TO GO FORWARD OR BACKWARD. IS THE POWER SEAT SYSTEM A GEAR SYSTEM, OR HYDRAULIC SYSTEM?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2216
Points
Anonymous
Level 1:
  • Posted on Mar 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1346
Points
My power car seat reclines does not come back up all other funtions normal what can i do
Anonymous
Level 1:
  • Posted on Feb 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1346
Points
Check the fuse for power seat control. The fuse # and location are listed in the owner manual. It is one of the larger fuses, # 50 if I remember correctly. The fuse box is located on the passengers side of the dash. You will see it upon opening the passenger door.
1helpful
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Why does my power seat in 1986 corvette just the back will not work
either the key for that function is broken,or the cable to power motor under your seat is coming loose or broken
2answers
How can i move a power seat that wont move
On these case go with the solved problems related to these issue.
Click the link below and follow the procedure:-----
1994 Lexus GS300: Power seat will not go back? http://howtobyme.blogspot.in/2012/05/1994-lexus-gs300-power-seat-will-not-go.html
1997 Toyota Avalon: Power Seat will not Move back? http://whatisbyme.blogspot.in/2012/05/1997-toyota-avalon-power-seat-will-not.html
1998 Chevrolet Corvette: Power Seat Control Now Working? http://schematicsdiagram.blogspot.in/2012/04/1998-chevrolet-corvette-power-seat.html
Power seat will not go Forward http://repairhelpcenter.blogspot.com/2012/10/power-seat-will-not-go-forward.html
Replacing power adjustable bucket seats to both heated and cooled seats?
http://schematicsdiagram.blogspot.com/2011/12/replacing-power-adjustable-bucket-seats.html
Volvo Seat Removal with Heated Seats? http://schematicsdiagram.blogspot.in/2012/07/volvo-seat-removal-with-heated-seats.html
How to Remove Rear seat on Rover 600? http://repairhelpcenter.blogspot.com/2012/01/there-are-3-10mm-bolts-at-back-of-seats.html
How to remove Seat? http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-seat-on-acura-integra.html
These will help.
Thanks.
Power seat not working
broken bar under seat or worn
1helpful
2answers
Drivers power seat does not work 1987 corvette
Clean your the pins on the control located under and attached to the control in your center console.
1helpful
Fuse diagram for 1993 jeep cherokee the power seats stopped working trying to figure out what fuse needs to be replaced
In the Fuse Block, Cavity 5, is a Fuse 30A c/BRK
In this document you can find all about the Power Seats:
- 93ZJ-Secc-8R-Power-Seats
- 93ZJ-Secc-8W-Wiring-Diagrams
Good luck (rated this help).
Power seat EGR
1981 corvette no power to the power seat need location of the fuse
1993 Corvette seats won't move
Replace the seat motors. that's what you get for buying a Corvette!
1helpful
I cannot read what any of the fuses are for. I need a diagram because my power seat quit working. thx
The power seats use a circuit breaker. Power Accessory (PWR ACC) As the breaker cools off, it works again. Suggest your problem is in the power seat switch, or the motor for the power seat.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
