Question about Dell Inspiron 1000 Notebook
Where is the Sleep Button to put D-I'n-1000 into hibernation
Can anyone please tell me the location of the "sleep button" (not the same as the power button), to put a Dell Inspiron 1000 into hibernation (after making appropriate power setting), please? (Mislaid hardcopy manual, and nothing is found under search for "Sleep button").
  • pellis Jul 19, 2008
    Thanks for the advice, especially if there is no sleep button, but as I rarely move the laptop, I prefer to avoid opening and closing the lid (earlier laptops have usually failed from excess lid-opening)
    Paul
  • Anonymous Jan 03, 2009
    The control panel shows separate settings for the sleep and power button, but I can't find a sleep button.
    President:
  • 778 Answers
Close the lid and it will actuate the Hibernate mode.
Posted on Jul 19, 2008
  • 3,940 Answers
There is no SLEEP BUTTON per se on and Inspiron 1000 system.
Enabling Hibernate is easy enough though. Go to Control Panel, POWER OPTIONS. In the power options window, click the hibernate tab and ensure the ENABLE HIBERNATION checkbox is checked., then click the ADVANCED TAB. Look for the "When I close the lid of my computer option and select HIBERNATE.
Since that system doesn't have a SLEEP BUTTON, that option may be listed, but is of no use.
Hee is a link to the I1000 manual
http://support.dell.com/support/edocs/systems/ins1000/en/Y69601LRs.pdf
  • IQUIT Jul 19, 2008
    For what it is worth, the hinges on that model are pretty decent and wear well, only thing you need to do is ensure the hinge screws on the bottom of the chassis stay tight (#1 phillips) to maintain a good ground for the LCD (they ground the LCD to the chassis)
Location sleep button
Usually the sleep button and the power button are one and the same. If you are running Windows, you can go into the control panel. select power options and then choose what pressing the power button will do.... you may choose hibernate, sleep or shutdown. If I knew the model of your computer and operating system, I could provide a more detailed solution.
Sep 29, 2013 | Acer Aspire Computers & Internet
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Pleomax keyboard pkb 700b shortcut does not work
look below the enter key one turbo key also available
if you want to use three of these buttons like power off,sleep,etc
press turbo key and then press one of these its really working and very quite
Amrit
Jun 13, 2012 | Samsung Pleomax PKB-700B Keyboard
How i can enable hibernate option
xp
To automatically put your computer into hibernation
You must be logged on to your computer with an owner account in order to complete this procedure.
1. Open Power Options in Control Panel. (Click Start, click Control Panel, and then double-click Power Options.)
2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
If the Hibernate tab is unavailable, your computer does not support this feature.
vista
Go to the command prompt icon in the Start menu under Accessories and right click the icon: click "Run as administrator".
Paste: "powercfg.exe /hibernate on" and hit Enter and also paste "powercfg -h on" and hit enter just to be safe.
Open Control Panel and type in "Hibernate" in the Search.
Click "Turn hibernation on or off"
Click "Change advance power settings"
Scroll to and expand the "Sleep" option.
Select "Off" to the "Allow hybrid sleep" option.
Scroll to and expand the "Power buttons and lid" option.
Select "Hibernate" for the "Sleep button action" option. 10. Select "Hibernate" for the "Start menu power button" option.
windows 7
Click the Start button, and then click the arrow next to the Shut down button.
Sleep and Hibernate located on the menu
If sleep or hibernate aren't available, it might be for one or more of the following reasons:
Dec 05, 2010 | Dell OptiPlex GX620 PC Desktop
My laptop battery/preparing to hibernate
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
if it boots up to your operating system
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Mar 07, 2010 | Samsung NC10-14ROBL Notebook
When I close the laptop and reopen it, there is just a black screen and I can't get it to work. So I end up having to turn off the computer. Also when I go to the shut down from the start menu, the standby...
You probably have a sticking hibernate, or sleep button. Near the hinge, there is a tiny pin looking thing sticking up. When you shut the computer, this presses against a switch below the case and puts the computer into sleep or hibernate mode. If this sticks, it won't boot up right. Shut the computer down and use canned air to blow out at the pin opening to clear any debris.
Sep 30, 2009 | Dell Inspiron 1300 Notebook
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Dell Inspiron 1000 Notebook Logo
382 people viewed this question
Alun Cox
