Question about Car Audio & Video
I recently lost the power to my car, which resulted in the loss of the radio code i do not have the radio card which is supplied with the vehical it is 3rd hand.
  • 25 Answers
Try pulling the deck from the dash, sometimes it is written on the outside of the unit.
Posted on Jul 19, 2008
How to fix radio nissan navara after entering code. eer comes up
Nissan Required Original manufactures security code required to active your Nissan car radio power loss witch is provided on behind the radio on Sticker
Never take the serial number from any printed paper work guid since this may not match the actual Nissan radio fitted to the car instead take the serial number either a label or engraving on the top or side of your Nissan stereo to ensure the supplied Nissan radio code is accurate
Jul 01, 2016 | Nissan Navara Cars & Trucks
I have lost the pin code card to the radio in my Kia Rio 2010 model
The supplying Kia dealer might have a note of the number but if not and your radio is the original they should be able to supply the number at a price from the vin or registration number.
If the radio isn't original it will have to be removed and the code obtained from the serial number.
Jun 26, 2016 | Kia Cars & Trucks
Chevrolet S10 Pickup Radio Loss of Power
You must buy that code to activate the radio again. You may be able to get it here: Can find your factory car stereo radio code We can help
Jun 15, 2017 | Cars & Trucks
Can i connect a Uniden UH089NB UHF 2way radio to 12 & 24v
Hi John,
Page 5 of the manual for this radio specifies a 13.8 VDC (12VDC car / truck electrical system) power supply to power the radio.
Connecting to a 24 VDC system will damage the radio and likely require expensive repair or replacement.
Feb 01, 2012 | Uniden Radio Communications
What can be done if a radio reads off when switched on after battery has been temporarily removed?
You will just have to re-set your stations, etc. Very common when the battery is disconnected or removed. In case the code is lost, I taped mine to the top of the radio and kept a copy in the glovebox. A dealer should be able to supply a radio code from your registration.
Oct 23, 2011 | 2001 Volvo S40
Battery went flat so need radio code for renault megane
With the car, comes a plastic "infocard" with the radio and alarm codes. If you lost the card or didn't receive it with the purchase, you can ask for the code to the radio manufacturer, they'll ask you the serial number of the radio and the car and they'll send you the code.
Jan 12, 2010 | Car Audio & Video
Radio code
I have a 2001 Mitsubishi Sport. I was doing some work to my battery and my radio locked out. I put a code in that I thought it would be and after 3 codes it would not let me add anymore codes. I took my vehicle to the dealership(no charge) and he went in and got the serial numbers off of the radio and looked into his computer and gave me the code. Of course the radio was locked out. He told me I had to have the ignition turned on for 30-45 minutes and the radio would reset for me to put the code in. I let it sit in the garage for an hour and went back out and it worked. I just put the code it.
Feb 14, 2009 | 2001 Mitsubishi Montero Sport 4WD
Radio not working
If you have recently changed the battery or lost power for any reason your radio may require an anti theft code, check your manual to see if this even applies to your vehicle. You may be able to find code behind the glove box in some cases. Or look up your vehicle online to see if any codes are posted. If the clock is working you have power.
Jan 11, 2009 | 2002 Nissan Xterra
Memory loss since changing fuse!!!
The unit will have 2 fuses, or at least a second power supply that is generally connected to continuous power, best bet is straight from the +ve batt terminal. If this power supply has been disconnected or has a blown fuse, then you will also loose memory functions from you radio.
  1. Check first under the bonnet for a memory backup fuse holder that has generally less than 1 amp fuse,
  2. no luck, then about the rear of your fuse box for a fuse holder,
  3. or worst, behind the unit up under the dash. The wire from the back of the stereo on Sonys is generally the RED one for memory backup
restoring this power supply to your stereo will then allow for all your presets to be retained in memory
Good luck, happy to talk to you more about the problem, a "FixYa" rating will help my profile
regards
Graeme
Feb 14, 2008 | Sony CDX-GT300 CD Player
Memory loss
you need to remove the radio and swap the red wire for the yellow wire and vice versa, they have bullet connectors to allow you to do this, basically the permanent live and the ignition live are the wrong way round.
Nov 27, 2007 | Sony CDX-GT300 CD Player
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
