Question about EPoX (EP8K3AE) Motherboard
EP8 RDA+ won't power up
When I turn on my computer it starts to power on then shuts down.The power supply and CPU fan start momentarily and then shut down.I found some bulgy capacitors (5 x 1500mf) and replaced them.Still no good.Anyone got any ideas?
  • joegigs Jul 20, 2008
    Tried your suggestion.Still no good.Thanks anyway.It was worth a try.
    Also what I do get is a FF momentarily followed by a C1 on the LED readout on the M/Board and then system shuts down
  • 781 Answers
When I had this problem it was the BIOS you may have to reset the BIOS on motherboard somewhere printed will be word to the effect resetbios (different M/board have different words) it should be a 2 pin jumper with a jumper only on 1 pin fit jumper over both pins reboot quickly turn of replace jumper over one pin try a restart
Posted on Jul 20, 2008
Shuts down 2 seconds after powering on.
Don't know this exact server. But my guess it is either a heat issue or a power supply issue. Turn it on with the cover off. Check the CPU fan(s). If your CPU is getting too hot the system might be shutting down power to save it. If everything seems cool it might be the power supply I have seen it when the power supply fan goes out on the power supply and the caps inside start to sizzle. Voltage ramps up and fail.
Hope this helps.
Also, Something that has tripped me in the past. Make sure the power button is not stuck. I had a server that the power button stuck down and it would turn itself off. Took me 2 CPU fans and a power supply to figure that out. LOL
Oct 08, 2013 | HP ProLiant DL385 Server
My acer Keeps shutting down Could it just be dirty or do need to upgrade the power supply
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 18, 2012 | Acer Black AX3400G-U4802 Desktop PC with...
My computer suddenly lost power and now it won't even turn on.
replace the power supply of your cpu check if the blower fan is spinning during power on it means that your power supply is good if not replace the power supply with a new one
Sep 12, 2011 | Dell Inspiron 537 MT Desktop Computer
Hi, I ahe a dell computer model number dccy, i want to know why it turn off by itself, when it get to hot, when i have more than ten minute working with it, why if turn off
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Aug 16, 2011 | Antec Computers & Internet
When I turn on my computer it runs for a couple of seconds and then stops.
Unplug everything inside the computer, except the motherboard and the front panel power on switch. Power up the computer. If the PS fan continues to run, (power supply doesn't shut down)and the CPU fan runs, then power off the unit and reinstall each device, one at a time, turn the power supply on after each device is installed (and off, before installing the next device).
You can not easily start the power supply if it is not connected to the cpu motherboard.
If the power supply shuts down with only the motherboard attached, then you will need either another power supply, to test the MB, or another MB to test the power supply.
R
Feb 02, 2011 | Acer DPS-420GB (dps420gb) Power Supply
My gateway computer do not turn on.the fan try to start and stop.what should be happenning?
I think that the CPU fan isn't working as it should and the CPU is overheating quickly. If the CPU is heating too fast, the mainboard is automaticly shutting down the all PC to prevent damage. Your thermal paste might be gone. Isn't the computer giving any sounds or LED flashes ?
Nov 02, 2010 | Gateway 830GM power supply **FREE **...
Computer frequently shuts down unexpectedly/ fans very noisy
You might have a cooling problem due to a fan malfunction. It is not clear whether it's the power supply fan or the CPU fan; in the latter case you might also have a thermal coupling problem. The symptoms you describe certainly seem to point to such.
My advice would be to replace the fan (or the whole power supply; you might also want to purchase a "Silent Power" unit for quieter computing). If it's the CPU fan and you are comfortable with, or know anyone comfortable with a bit of PC servicing, you might want to also unmount the heat sink from the CPU and replace the thermal paste between CPU and heatsink. Clean the heat dissipator (the black metal grille over the heatsink) with hot water and a bit of soap and dry thoroughly, or wipe it energically with a dust brush, before mounting the new fan on it.
Feb 28, 2010 | HP KQ499AA Pavilion Elite M9360F Desktop...
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
Turns on, then shuts down before anything shows on monitor
Is there more than one fan inside the computer? Did you double-check the connection from the fan to the motherboard? Sometimes a computer will shut down if it doesn't sense that the fan is turning on, to prevent the computer from overheating.
Jul 25, 2008 | Compaq Presario S5100NX (E120866) PC...
Computer shuts down problem
When you take the cover off and start up, are all of the fans spinning? If the CPU fan doesn't spin, the system will shut down soon after starting to prevent over heating the CPU
Feb 21, 2008 | Intel V2 (INTPRI) PC Desktop
EPoX (EP8K3AE) Motherboard Logo
99 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
