Question about Rowenta Professional DX8800 Iron
Leaking professional luxe iron
My Iron keeps leaking. I've cleaned it and don't know what else to do.
  • The Intrpid Aug 17, 2008
    I have the same problem and have not heard of a solutionHELP please!
  • Rowenta Master
  • 43,501 Answers
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 15, 2010
Plug gets very hot and sometimes the iron doesn't work
your plug needs replacement. you have to put high wattage plug ,because iron has 1000watts or 4 amphere load.
Aug 15, 2011 | Rowenta Professional Luxe DM880 Iron
I have a rowenta proffesional luxe iron but the cable keeps turning it off so when i move the cable it goes back on and when i am ironing it shuts off
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
Apr 10, 2011 | Rowenta Professional Luxe DM880 Iron
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
Rowenta iron won't heat
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 10, 2010 | Rowenta Professional Luxe DM880 Iron
Leaking iron
Here is a tip that will help tou figure out your problem...
heatman101
Apr 24, 2010 | Rowenta DZ1900 Iron
Iron does not heat
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
heatman101
Oct 18, 2009 | Rowenta Professional Luxe DM880 Iron
Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 06, 2009 | Rowenta Professional Luxe DM880 Iron
DM880 Rowenta Professional Luxe Iron
The thermostat is bad...
heatman101
Jul 20, 2008 | Rowenta Professional DE880 Iron
Rowenta Professional DX8800 Iron Logo
545 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
