Question about Vizio L32 32 in. LCD HDTV
SCREECHING AUDIO TWO DAYS OUT OF WARRANTY (IKNOW IT'S A COINCIDENCE) OUR TV MODEL #HDTV10A STARTED AN INTERMITTENT SCREECH/HISS SO LOUD IT SCARED THE B'JESUS OUT OF MY WIFE. I CALLED VIZIO AND THEY WANT $299.00 PARTS AND LABOR TO FIX THE PROBLEM. HOW CAN THEY KNOW IN ADVANCE HOW MUCH? ALSO: WE PAID $599.00 FOR THE TV SO IS IT REALISTIC TO BELIEVE THAT A REPAIR DIAGNOSED OVER THE PHONE WILL COST 1/2 AS MUCH AS I PAID FOR THE TV? ARE LOCAL REPAIR SHOPS ABLE TO REPAIR? ANY ADVICE WILL BE APPRECIATED. I'M IN THE OIO6O ZIP CODE.
  • gfaiman Sep 09, 2008
    We are suddenly having the same problem with our 37 in. vizio. Any outcomes or explanation as to what it was?
  • jason248 Dec 26, 2008
    I have the same problem with my 42" ive been thinking about contacting them about it. At first is was only on the coax input but now it does it on all inputs. It can be really loud and scare the **** out of you or very quiet and you can just barely hear it and no other sound. its definitely interesting.
    Is there a separate board just for the sound? or is it all integrated into the main board?
    -Jason
    Problem Solver:
  • 10 Answers
My Vizio (don't know model # off hand, 32" bought at WalMart in Jan), is doing the same thing. It did it once the day I set it up; thinking it was just a glitch or something about my lack of knowledge with HDTVs, I powered it off (the hard way, yanking the power cord, as it won't turn off any other way) and restarted it, everything seemed OK. It did it again around April, same thing, just a glitch I figured. I changed some cables, attached more devices, and it has been doing it about twice a week now.
Sometimes it is the full video lockup, with vertical green lines, and full blast audio screech. A couple times it has only partially locked up the video (green vert lines, but still some movement), and no audio screech. Did it last night most recently, hence my google search.
Anyway, my point is, this is probably more common than we were both thinking, and they know just from your description what the problem is. I would try to have them repair such a known-issue free of charge, even out of warranty.
Posted on Jul 21, 2008
  • macinmn Apr 30, 2014
    appending my previous remarks, issue seems to happen when using the component RCA-type inputs (yellow-white-red). Since moving to using other inputs, HDMI (which fried due to lightning) and now Composite (Blue,Green,Red,+audio), the issue never reoccurred. TV still running great for over 7 years.
My Maytag washer model MAV208DAWWmakes a loud screech at the end of the spin cycle, and the clothes are sill wet
That is the brake. Your clutch maybe wearing out. Or the belt maybe slipping because the rollers for the motor maybe wearing out.
Jan 15, 2016 | Maytag Washing Machines
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
No tv picture and intermittent audio
Check the cables and connections
Apr 13, 2014 | Tatung Televison & Video
Screeching noise
Your car needs alignment. The screaming noise comes from tires being dragged over aspnalt. This wears tires very fast.
Nov 18, 2013 | Cars & Trucks
I have a problem with hiss coming from the sound bar (ZBase 550 HSD) when using my digital cable box. It is not an issue with PS3 etc. I have the sound on the cable box turned to max, but I still hear a...
Hello ZVOX Owner,
The hiss you hear is generated by the analog audio output of the cable box. The best way to eliminate this hiss to use the digital output of the cable box. The preferred way to do this is to connect the digital audio output of both your cable box and your PS3 to the your TV (I presume your TV has two digital audio inputs.)
Your TV has a digital audio output. You should connect the digital audio output of your TV to the digital input of the ZVOX.
This should reduce or eliminate the hiss and provide convenient video source selection via the TV.
From Fred P. at www.zvoxaudio.com
fred@zvoxaudio.com
Jan 27, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Philips tv model id: 19pfl5422d/27 terrible loud sound
The issue is 4 1000uF X 10V on the main board under the shield close to the connector that from the power board. you will see them because they will be FAT( exploded)
Feb 28, 2009 | Televison & Video
When filling with the side fill pump makes loud screeching noise
Hi Tom. if the noise is a loud SCREECH that almost sounds like a wounded bird, you need to replace the water pump. The part is easy to replace with no tools and you can get one from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
Dec 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Nov 11, 2008 | RCA P60921 60" Rear Projection Television
Vizio L32 32 in. LCD HDTV Logo
279 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
