WASHING MACHINE CAUSING ELECTRICAL EARTH PROBLEM WHATS WRONG
  • 41 Answers
Check the machine for water leakage onto any electrival components if no leaks then check the heater element there should be no reading on a ohmmeter between the connections and earth connection if there is the element has failed
Posted on Jul 19, 2008
My washing machine whirlpool when me conect electrical before choose program keep tripping. I remove earth wire and check again same problem . I chek heater, thermostat and motor its ok, Remove earth wire...
Hi there is a short circuit in the machine,either motor or the waste pump there is also a mains filter under the top covering or lid of the washer sometimes this is faulty or the cable has become wedged under the washer exposing shorted live wires please unplug the washer before trying any attempt to find these faults I hope that helps you in your quest eric
Nov 16, 2017 | Whirlpool Washing Machines
Forgot to open water supply for my new washing machine and when it started flashing I only realized the problem.As soon as it washes it trips my main switch and says Earth Leakage????Please help!!!!!
Hello Dora,
An Earth-leakage circuit breaker (ELCB) is a safety device used in electrical installations with high Earth impedance to prevent shock. It detects small stray voltages on the metal enclosures of electrical equipment, and interrupts the circuit if a dangerous voltage is detected.
You should have an appliance service person come out for a service call since there may be a dangerous shock hazard present on the machine.
Thanks,
Mario
Apr 17, 2016 | Washing Machines
Hotpoint Aquarius wm61 trips as soon as its filled with water,if I remove alot of the water it will allow me to spin
If you mean that the machine is tripping the circuit breaker then that is an indication that the water is creating an electrical current path to Earth. The heating element is normally enclosed in a metal sheath but if this is compromised then water will get in and current will then leak to earth, causing the circuit breaker to trip. The heating element can be replaced, but the cause of the damage to the element should also be determined to prevent it happening again. The rotating drum can become partially detached from it's mount and end up hitting the heating element when spinning, causing the element to be damaged. The drum mount (often called a SPIDER) may therefore also need replacing. If you machine was making a lot of knocking noises when in spin cycle then it would certainly indicate a broken mount.
Feb 08, 2016 | Hotpoint Washing Machines
How to repair a short it a power cord on a front loading washing machine
have you checked the three places the power cord is bolted into the washing machine? if a nut is loose that could be causing the problem. If you have a shorted cable I would recommend buying a new cable they aren't that hazard!
Sep 28, 2015 | Kenmore Washing Machines
Why does the earth fault breaker shut down when I use my washing machine?
I assume you have checked the earth connection to the ground.usually under sink onto copper pipe.
if there is an intermittent fault on any electrical appliance then the breakers will jump and try to send any residual current to earth to save someone receiving a full force electric shock.
Condensation on the machine electrics could be a good place to start or water reaching any electrics in the same room as machine.this include moisture or damp at the wall socket
Feb 11, 2015 | Washing Machines
Ground leakage detected device cut the power
Take wires out of plug and the wire from the connecter box of machine. With multi tester test earth to live and earth to neutral. If there is a short circuit it will show on which wire it is. Next disconnect live and neutral wires from motor and run test on all wires. If no short the motor is faulty and test the motor connectors. If the short is not found the motor is not the problem but the control system. Disconnect all wires from controls and test everything isolated and individually.
Apr 16, 2013 | Washing Machines
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
