Question about Dishwashers
Speed queen gas dryer will not start up. When i try to turn on the dryer it causes the breaker to trip off.
  • 833 Answers
My first thought is the motor start capacitor. This 'kicks' the motor up to speed. If it shorts, the unit will blow the breaker.
Make sure that the drum turns easily by pulling on the belt. If not, find out why...that's the problem.
Make sure the unit is unplugged before starting any work!
Posted on Jul 19, 2008
My dryer will not start
If you hear the motor then the belt is broken If you have the control panel working it is no guarantee that the breaker didn't trip Find the breaker in your breaker panel and reset it.
Nov 29, 2013 | Speed Queen Dryers
Speed Queen dryer not working after I pressed in the knob while turning!!
check your circuit breakers it may have tripped
Nov 22, 2013 | Dryers
My speed queen dryer model #AES68AWF doesnt heat what could it be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
My speed queen dryerit does'nt start at all. aem453
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 04, 2011 | Speed Queen Dryers
I have a speed queen electric dryer model number aem45300. problem the dryer runs but does not heat. We cleaned out all the area that contained lint. Is there a reset button for the heating element in...
There is no reset button, check yoru breaker, by turning FULLY OFF (somewhat forcefully off) then back on and test again.
All thermal limiters will auto reset when cooled...
Mar 04, 2011 | Speed Queen AES17AWF Electric Dryer
I have a Speed Queen dryer that just stopped last night. There appears to be no power getting to the unit--dryer does not start, light does not come on, timer does not advance--yet the circuit breaker...
Hello
Is there power at the dryer receptacle? Is the dryer wired directly or does wire from electrical breaker go to a receptacle first? Have it checked with a meter. If unit is wired directly have it changed to a receptacle and cord. Make sure there is power at the connections on the dryer. If everything is okay, then it is a dryer problem
John
Nov 09, 2009 | Speed Queen AES68AWF Dryer
I have a speed queen gas dryer. do i have to
It would be safest to turn off the gas supply. You should have a gas **** in line for this purpose.
Aug 29, 2009 | Speed Queen Dryers
Problem with speed queen 30EG. Dry ignitor turns on trying to turn on the burns but the dryer turns off in about 5 sec. If I turn off the gas valve the dry stays on.
Sounds like the thermistor. It is the whit plastic piece on the front of the motor - blower assembly with 2 wires going to it.
Aug 24, 2009 | Speed Queen CES68AWF Dryer
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
