Question about Kenmore 46462 Front Load Washer
He2t F-o1 What does this code mean and how do I fix it.
  • bevandrob Jul 19, 2008
    THANKS FOR THE HELP. IT APPEARS THAT MY CCU IS GONE. I WILL BE REPLACING IT. YOUR INFORMATION WAS TOTALLY ACCURATE AND VERY HELPFULL.
    THANKS AGAIN
  • 246 Answers
If memory serves me correctly this is a main control board error. To find out for sure, Remove the lower front panel of the washer. (the 1/4" screws are across the bottom) Just inside that panel is a tech manual. Skip to the error code section. For an F01, the steps should be unplugging it for 2 1/2 minutes (to reset the main circuit board). I would also pop the top cover (the 1/4" screws are in the back side of the top panel) and check for any
loose connections on your main circuit board ( front top, right hand corner) WARNING - Circuit boards are delicate and an static shock could ruin them. Ground yourself (always keep one hand touching the frame of the machine) before touching the connections. Also try following the black hose on the top, right hand side towards the rear. It goes to your pressure switch (round cylinder 2 1/2 - 3" wide). Give it a firm tap with something insulated (the handle of your screw driver for instance). If the switch gets stuck it can cause a false f01 error code.If all steps fail, you can contact a local servicer. I only suggest this because I have found there are other things (not printed in the tech manual) that will give a false f01 error code. MAKE SURE THEY PROVIDE A WARRANTY FOR THIER WORK! If you would like to replace the board yourself, they can be obtained from the local appliance parts supply stores or online from the manufacture.
Posted on Jul 19, 2008
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Why is my washing machine saying f o1
F01 error code on most Hotpoint washing machines means "motor triac short - check motor and module connections".
Dec 22, 2012 | Hotpoint Washing Machines
E-o1 code
Call your nearest repair shop, tell them your problem and ask what the code means. Then come back and I might be able to tell you how to fix it yourself if you are handy and don't need parts.
Jun 14, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Dec 05, 2009 | Kenmore HE2 Plus Front Load Washer
I have the F-01 flashing on my Kenmore HE2t. What to do?
Pull off bottom panel and check the service sheet for error code meaning. hope this helps...
Oct 23, 2009 | Kenmore Washing Machines
Kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Sep 23, 2009 | Kenmore Washing Machines
How to instal coads on digivox
press menu then 1570 opens secret menu then go to provider c******s or n*hell or whoever you must use your provider enter key no in line no. 1 its the 00 line then use remote to imput the no. and letters the colour keys and the audio /pause info key when you have oo line done press ok to store then put in o1 line and the o1 line code after you have oo line in and saved you use the same line only put o1 in then the o1 code in then save again make sure your emu is turned on that should do it
Apr 04, 2009 | StarTech.com StarView SV211K 2-port KVM...
The Norton symbol on my toolbar has a red circle and a white cross. When I try to open Norton I get a blank page.
The short answer is that your computer is infected with spyware that actually infects Norton itself, so that it cannot remove it. it is Fixable but its complicated and I'm unsure how much you know about computers. It might even be easier to reformat.
but if you do the following it will fix it.
(Disclaimer: if you are not comfortable with the following please get a professional or don't attempt. The easiest way is to reformat)
also i personally use the following sites on a daily basis and stand by them 100%
Get the Pocket Killbox from here:
http://bleepingcomputer.com/files/spyware/KillBox.zip
Unzip the file to your desktop.
Go offline until this is completed (you may wish to print these instructions).
Boot into Safe Mode and do a search for these files:
guninst.exe
popup_bl.dll
systr.dll
svrhost.exe
Delete any found, and then do a search for param32.dll
Run Pocket Killbox and paste the full file path of param32.dll in the box and click on Delete on Reboot. Click on the button with the red circle and an X in the middle; you will get a message saying File will be deleted on next reboot, Process and Reboot now? Click Yes to reboot. (Note: the 'file path' will be something like C:WINDOWSSystem32param32.dll)
Delete any unwanted icons from your desktop.
Empty your Recycle Bin.
Go to AddRemove Programs in your Control Panel and remove ADVANCED SEARCHBAR, if found.
Scan with hijackthis (download it here), and have it fix the following entries:
R1 - HKCUSoftwareMicrosoftInternet ExplorerMain,Search Bar = about:NavigationFailure
R1 - HKCUSoftwareMicrosoftInternet ExplorerMain,Search Page = about:NavigationFailure
R0 - HKCUSoftwareMicrosoftInternet ExplorerMain,Start Page = http://www.newgenlook.info/ad/ad0278/
R1 - HKLMSoftwareMicrosoftInternet ExplorerMain,Search Bar = about:NavigationFailure
R1 - HKLMSoftwareMicrosoftInternet ExplorerMain,Search Page = about:NavigationFailure
R1 - HKCUSoftwareMicrosoftInternet ExplorerSearch,SearchAssistant = about:NavigationFailure
R0 - HKLMSoftwareMicrosoftInternet ExplorerSearch,SearchAssistant = about:NavigationFailure
R1 - HKCUSoftwareMicrosoftInternet ExplorerMain,HomeOldSP = about:blank
R1 - HKLMSoftwareMicrosoftInternet ExplorerMain,HomeOldSP = about:blank
R3 - URLSearchHook: (no name) - {C7EDAB2E-D7F9-11D8-BA48-C79B0C409D70} - (no file)
O1 - Hosts: 69.50.166.11 www.google.co.uk
O1 - Hosts: 69.50.166.11 google.co.uk
O1 - Hosts: 69.50.166.11 www.google.ca
O1 - Hosts: 69.50.166.11 google.ca
O1 - Hosts: 69.50.166.11 www.google.es
O1 - Hosts: 69.50.166.11 google.es
O1 - Hosts: 69.50.166.11 www.google.de
O1 - Hosts: 69.50.166.11 google.de
O1 - Hosts: 69.50.166.11 www.google.fr
O1 - Hosts: 69.50.166.11 google.fr
O1 - Hosts: 69.50.166.12 www.go.com
O1 - Hosts: 69.50.166.12 go.com
O1 - Hosts: 69.50.166.13 astalavista.com
O1 - Hosts: 69.50.166.13 www.astalavista.com
O1 - Hosts: 69.50.166.13 astalavista.box.sk
O1 - Hosts: 69.50.166.13 cracks.am
O1 - Hosts: 69.50.166.13 www.cracks.am
O9 - Extra button: Advanced Searchbar - {43F02779-6D88-4958-8AD3-83C12D86ADC7} - C:PROGRAM FILESADVANCED SEARCHBARTOOLBAR.DLL
O9 - Extra 'Tools' menuitem: Advanced Searchbar -{43F02779-6D88-4958-8AD3-83C12D86ADC7} - C:PROGRAM FILESADVANCEDSEARCHBARTOOLBAR.DLL
O18 - Filter: text/html - {E27A20A0-BE61-11D9-9E02-0008C7E6B749} - C:WINDOWSSYSTEMHIJENCA.DLL
O18 - Filter: text/plain - {E27A20A0-BE61-11D9-9E02-0008C7E6B749} - C:WINDOWSSYSTEMHIJENCA.DLL
Be sure all windows are closed, other then hijackthis, before hitting Fix checked.
A few more things need to go.
1. Open a DOS box by typing "command" (omit the quotes) in the "Run.." option under your Start button menu.
- At the command prompt in the DOS window, type the following command:
regsvr32 /u C:WINDOWSSYSTEMHIJENCA.DLL
Close the DOS window after the command command completes
2. Run HijackThis again and have it fix:
R3 - Default URLSearchHook is missing
O2 - BHO: ToolHelper - {CDEEC43D-3572-4E95-A2A5-F519D29F00C0} - C:PROGRA~1ADVANC~1TOOLBAR.DLL (file missing)
O2 - BHO: (no name) - {4948A8E1-BE50-11D9-9E02-000855D4C36C} - C:WINDOWSSYSTEMHIJENCA.DLL
O18 - Filter: text/html - {7CDBC5E3-BE71-11D9-9E02-00084A455E60} - C:WINDOWSSYSTEMHIJENCA.DLL
O18 - Filter: text/plain - {7CDBC5E3-BE71-11D9-9E02-00084A455E60} - C:WINDOWSSYSTEMHIJENCA.DLL
3. Search your system for the C:WINDOWSSYSTEMHIJENCA.DLL file and delete it if it still exists.
Sorry but this particular virus/spyware has no real quick fix and it has many many names.
Nov 12, 2008 | Computers & Internet
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Kenmore 46462 Front Load Washer Logo
237 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
