Question about Siemens Lands Phones
Cannot set up system so that second, remote 'phone can be used. Refuses to set up second 'phone as Base 2. Where do I find the pin number required? I wish only to use the system as a simple telephone network, having no interest in text-messaging. Is manual available in English? System = S450 SIM Duo
We have just the panasonic KX TCA 132E digital phones but we cannot get a line ? any one can help?
Posted on Aug 25, 2008
A) Found and downloaded English Language user manual from the net.
b) Discovered that 'phone set-up should have been AUTOMATIC!
c)Unloaded batteries from both handsets, and then replaced them.
d) System up and running!!
Thanks for your consideration,
Raygr.
Posted on Jul 20, 2008
ANSWERING MACHINE
Sherry:
I believe that some how the security code #99 got changed. You may want to reset that code as #99 no longer works. From the manual:
Setting a Personal Security Code (PIN)
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal
Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code"
followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press
menu again."
Note: The PIN code is set to "80" at the factory.
Jun 13, 2014 | Uniden DECT1560-4 DECT 6.0 Expandable...
Lost my pin to access messages. The phone model is a Panasonic cordless Model TGA542AL.
Which model of Uniden phone do you have? Do you remember the PIN that you have programmed into the phone? (If the PIN is not set, you can't access the answering system remotely. The Uniden phones that I know don't have a default PIN.)
For the DCT648, to access the messages remotely, dial your phone number and wait for the system to answer. Press 0 followed by your 2 digit PIN (within 2 seconds of pressing zero) while the greeting is playing. To play back all of the messages, press 0 2. If the unit is off, then you need to press 0 followed by your PIN (within 2 seconds) after 10 rings and the beep. Press 0 6 to turn on the unit.
Other Uniden phones use a 4 digit PIN. On the DECT1080, when the greeting plays, press * followed by the PIN. Then press 01 to play back the messages.
Uniden phone manuals are available at the product page (start at http://www.uniden.com and search for your phone) or from the Support page ( http://www.uniden.com/scat/cordlessphones_mnl ) . On the support page, you will need to use the drop down menu to change the type of phone (if you have a DECT phone) and then search through the pages. The manuals are listed in numerical and alphabetical order. One manual will cover several phones if the phone supports multiple handsets. So ignore the number after the dash if you can't find your exact manual.
If you add a comment with your phone's model number, I'll be glad to check the specifics for accessing the answering system for you.
I hope this helps.
Aug 30, 2011 | Panasonic Lands Phones
I have lost my manual and I don't know how to retrieve my messages from another phone when I'm away from home.
I hope this helps.
Aug 16, 2011 | Uniden Cordless Phone
Have lost my manual.....how do I remotely check my messages. I know there is some kind of code to use or # button
Which specific model of the Uniden 2.4 GHz do you have? The manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
For the DCT5280, when the outgoing announcement plays (after picking up) or after 10 rings and some beeps (the answering machine was off) when you call your phone number, press 0 followed by your PIN within 2 seconds. The PIN is a two digit code that you set when you were physically at the hanset or the base. (It's in the Ans Setup menu.) You will need to enter the 0 within 15 seconds of the machine looking for a response and the second digit of a command in 2 seconds of pressing 0.
I hope this helps. Let me know which Uniden system you have for more information.
Jun 16, 2011 | Uniden 2.4 GHz Cordless Phone System
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Phone on base showing it is "searching" for base.
check to see if the power cord is properly plugged in. You may have the phones on the wrong cradles, this wil cause them to search.
Apr 29, 2009 | Uniden Cordless Phone
Lost my manual and cannot remember how to get messages remotely
Since I have not idea what exact model you have this may or may not work... I hope it helps, as it is for a Uniden answering service phone.
Remotely Operating Your Answering Machine
Note: The answering machine will only playback messages for four minutes and then it returns to the command waiting mode.
To continue playing your messages, press [#] then [2] again within 15 seconds.
To operate from a remote location, use any touch-tone telephone and follow these steps:
1.) Call your telephone number and wait for the answering machine to answer
2.) During the greeting message, press [#] and enter your PIN code within 2 seconds;
How to enter a PIN
To play your messages from a remote location, you will need to enter a two-digit Personal Identification Number (PIN) or PIN Code.
Press the MENU soft key. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
Enter a two-digit security code (00-99) using the number keypad [0-9].
Press the OK soft. You will hear a confirmation tone.
You hear "To play incoming messages, press pound-two. For help, press pound-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following:
# then 1 Repeat a Message
# then 2 Playback Messages
# then 3 Skipping a Message
# then 4 Deleting a Message
# then 5 Stop Operation
* # then 6 Answering Machine On
# then 7 Memo Record/Stop**
# then 8 Greeting Record/Stop**
# then 9 Answer Machine Off
# then 0 Help Guidance
Apr 27, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Wharfedale digital orb twin phone
TO REGISTER A HANDSET
[At the base]
1. Press and hold the the PAGE button on the base station for at least 3 seconds. You have 90 seconds in which to register a handset.
[At the handset]
2. Press MENU and scroll to ADVANCED SET and press MENU
3. Scroll to REGISTRATION and press MENU
4. If necessary scroll to display REGIST.BASE and press MENU
5. BASE 1 2 3 4 is displayed and the registered base number is flashing.
6. Enter the number of the base you wish to register to your handset. If you have only 1 base station, press 1. If you have 2 base stations, press 1 or 2, etc.
7. When the display shows PIN---- , enter the base pin.
8. When the handset is registered to the base it is assigned a handset number.
If you have forgotten your PIN you will need to:
Reset your ORB
1. Press MENU, scroll to ADVANCED SET and press MENU
2. Scroll to RESET UNIT and press MENU
3.CONFIRM? is displayed. Press MENU
[NOTE: Entries stored in the phonebook and new answering messages are retained. You PIN will return to the Default setting 0000]
To Set the PIN
1. Press MENU and scroll to ADVANCED SET and press MENU
2. Scroll to PIN and press MENU
3. Enter the current 4 digit master PIN and press MENU. [Default setting is 0000]
4. Enter the new PIN and press MENU
Hope this has been helpful!
Rob
Dec 28, 2008 | Uniden Cordless Phone
Lands Phones Logo
252 people viewed this question
Top Siemens Lands Phones Experts
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
