Car acting strange. I when I start driving my steering wheel will turn hard left then turn hard to the right and won't doing this. The faster I go the more aggressive it gets. I have to hold the wheel with my might to keep the wheel from turning back and forth. I've only gone 15mph max since this issue arose.
Try this..... Put key into ignition and turn so lights come on (facia).. Do not start car... Turn the steering wheel left to right 90° approx a few times. This will be quite hard to do.
Then turn off ign and restart as normal.
If steering wheel light has gone out and steering is working you will need a new motor drive at some point.
Note.. Sometimes the fuse blows so check fusebox and replace if necessary.
Do you mean the engine overheat warning? The power steering problem is most likely a defective steering rack, they always act up when hot due to internal seal leakage and fluid bypassing the seal.
Gear shift is not totally in the park position - had the same problem with a 2011 Acura TL - a rubber band kept the gear shift lever from totally seating in the park position.
YOU HAVE AIR IN THE POWER STEERING SYSTEM.YOU NEED TO BLEED POWER STEERING PUMP FIRST BEFORE DRIVING VECHICLE.CHECK POWER STEERING FLUID LEVEL ADD MORE POWER STEERING UNTIL REACH FULL COLD MARK..RAISE VECHICLE FRONT WHEELS OFF THE GROUND.START ENGINE LET IT IDLE WHILE TURNING STEERING WHEEL LEFT TO RIGHT NON STOP DONT LOCK OR STOP STEERING WHEEL KEEP TURNING IT SEVERAL TIMES CHECK POWER STEERING FLUID IF LOW ADD UNTIL YOU GET COLD MARK ON DIP STICK DONT OVER FILL POWER STEERING PUMP BLOW A SEAL.IF POWER STEERING FLUID LOOK TAN COLOR SYSTEM FULL OF AIR.TURN OFF IGNITION LET CAR SET FOR A WHILE CHECK FLUID LEVEL.IF STEERING WHEEL FEEL STIFF HARD TURNING DONT DRIVE CAR UNTIL YOU HAVE NORMAL STEERING.IF STILL HAVE AIR IN SYSTEM BLEED SYSTEM UNTIL AIR IS OUT.
Hi the steering lock could be causing you the problem try turning the steering wheel hard left whilst turning the key and do the same hard right.
it may be hard to turn but you should find once you have moved it slightly it will unlock allowing you to turn the key so dont adjust the steering wheel turn it to the right as if your trying to turn to the right and if this dont let the key turn turn the wheel to the left it only needs to move slightly to allow the steering lock to free the key,
doing the above should solve you problem
give me a shout back if you have any further problems ok
When you brake you hear a strange noise. The sounds brakes may make, should be something you are familair with.
When doing 45 mph plus, the car starts to shake. Now tell me, youv'e not experienced this many times in your life!
Turning left or right could be a worn steering rack,mostly because you never change power steering fluid,or upper strut bearings or any other suspension parts starting to wear. Or, it's just you noticing different sounds, than when it was new.
When you turn the wheel too far to either side,you hear the power steering pump squealing and telling you to stop. Another bad practice.
Now I would conclude, that you need to strip all four brakes off the vehicle and completely go through some sort of brake repair or service. I hope you already figured that.
My opinion is strain yes damage no. You know when you turn the wheel all the way to one side the tires are "grinding" into the pavement this causes you to give it a little extra gas to get the car to move...right? But I don't think that would cause damage. If I'm wrong then you have the worlds' worst engineered car!
Turning lock to lock as you describe is making the steering pump work hard since the wheels are stuck to the pavement.
Keep in Mind that WITH NO POWER STEERING AT ALL The Faster you Drive the EASYER it is to Stear Lft & Rght. Having Said that If your Car is Hard to Steer While Sitting in PARK and Turning the Steering Wheel Left AND Right , This Sounds as if your Power Steering Pump Is Bad for1 and it May have Contaminated The STEERING RACK , this is A MAIN Component in the Steering System.
Power steering Belt or pump pulley. Could be that turning left puts more stress on your system then turning right and that's why you only hear it while turning left.
