Question about Philips Magnavox 27MS343S 27" TV
Older TV keeps going to static
I have a Sanyo Tv that is about 9 years old, it's not an lcd or plasma, just the old kind. It has Dish Network, and a dvd player hooked up to it. While watching tv, it will go to static. Sometimes, it will happen every few minutes, other times it will go for several hours without a problem, then it will go to static. Sometimes the static only lasts for a few seconds, other times it lasts for up to 15 minutes. At first I thought it was the satellite receiver because it is also 9 years old, but it happens while watching dvd's also. Thanks for your help!
    Sergeant:
  • 280 Answers
Without seeing it I would suspect a bad connection on the main board. As the board heats up the board expands and as it cools in contracts opening and closing a crack in the board. Sometimes a crack or bad solder joint both are sometimes hard to find and it is a lot of solder and wait and see.I have had some luck by tapping on the board with an insulated handel of a nut driver,.. the tv on and watching for any change. If i tapped around the board some areas were more sensitive than others. I then soldered that area. I would tap around again if the set did not react I assume the problem fixed
Posted on Jul 24, 2008
I'm trying to hook up an older sanyo TV to my dish network, and I only have the yellow, and white inputs... How do I do this?
Hi Lucas, If your dish network has an aerial in & out then you connect television (aerial in) to dish network (aerial out)......... I hope this helps mate........CHEERS..
Apr 24, 2016 | Sanyo Televison & Video
I have a sanyo DP50740plasma tv a few years old. Last night I got wi fi and hooked up a Samsung blue ray player and the sound quit working. the picture is clear on dish (on HDMI 3) and the blue ray p
What happens when you take the bluray hdmi out? or turn the bluray power off from wall? can you connect audio from bluray with a separate cable? often one device overrides the other. there may be a way of daisy chaining the devices
Dec 17, 2014 | Sanyo 50" Plasma Hdtv Dp50740a W/ Free...
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
What kind of HDMI cord do I need to purchase for this TV, I am running DISH Network also. Thanks!
There is only one type of HDMI cable, so any HDMI cable should be fine. Component cables are an alternative to HDMI cables, but keep in mind that component cables do not carry audio, so you will need to have the audio connected separately. Our HD receivers work great with HDMI or component cables.
Phillip Chang
DISH Network Customer Service Representative
Feb 08, 2011 | Sanyo 42 in. LCD TV
Audiovox 9'' drop down tv with poor sound
You need to go to cable instead of air and search for channel
Feb 07, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Philips Magnavox 27MS343S 27" TV Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
