Question about Electrical Supplies
Tekonsha P3 brake controller warning
After having a new brake controller installed, on first hookup, i got a Warning-Overload-No Brakes message. The only probable cause listed by Tekonsha is "P3 detects an excessive current overload condition during operation." The only thing i noticed is that as soon as i plugged the camper in to the truck, the camper's exterior lights came on. Related?
thanks for your help!
David
  • 51 Answers
SOURCE: brake and ABS warning lights on, trac off on.
You may have a bad abs controller. You need to get the code for the abs light from a shop or auto parts store.
Posted on Oct 08, 2008
emissionwiz
  • 79851 Answers
SOURCE: abs warning light stays on no problems with brakes
The brakes will feel fine until u need the ABS, when the light is on the ABS is disabled. You need to have the ABS system tested for trouble codes, if the light is on there will be a code or codes.
Posted on Nov 14, 2008
geharbison
  • 101 Answers
SOURCE: Abs and parking brake lights come on and stay on
There is probably a problem with you anti lock brake system. Have it checked at your local dealership. Brakes are a problem that should never be let go.
Posted on Dec 14, 2008
  • 1632 Answers
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Posted on May 22, 2009
mechanicm639
  • 253 Answers
SOURCE: my abs light is always on and now my brake warning light is on but brakes seem to be working fine
The ABS light is a warning that you have an issue with the ABS system. The red brake warning lamp is serious. It is telling you that there is an issue with the base brakes. Your car will be ok with an ABS light, but the red warning lamp could be really dangerous. You should have them checked ASAP. It could be from many causes. A park brake switch, low fluid, the causes are too numerous to list. Please for your safty have it checked. Good Luck
Posted on May 29, 2009
Clearing/resetting ABS and Traction Control system warning lights - 2006 Buick Terraza
As long as your car's brakes work and is safe to drive, take it to any parts store. They have error code readers that can reset these alarms. If they are not able to reset them then you will probably have to take your car to a brake shop for maintenance on your ABS sensors. Traction control is associated with the ABS sensors.
Nov 09, 2017 | Buick Cars & Trucks
When i pull my trailer ahead the trailer brakes lock up
The brakes system is surge? Not electric?
Probable cause is corrosion from sitting.. Rock the trailer back and forth while hitched( Not crazy like please- be gentle. ) Hit the brakes each way which takes a knack. It should break free. Problem is long term storage( over winter). They may also be stuck in reverse.. The controller. may need a hammer whack( universal adjuster)
May 05, 2016 | 9030 Voyager Electric Trailer Brake...
On my 91 cougar it sat for about 2 months due to a power steering problem I fixed that problem now my abs and brake lights stay on is it possible if I bleed all four brakes they might shut off?
"Is it possible if I bleed all four brakes they might shut off?"
If you bleed the brakes all you will do is remove any air in the brake lines and replace the brake fluid with new fluid. Do this in any event if the brake fluid is 2 yrs old or more.
This will have no affect on the ABS warning light and when the light is displayed the ABS has turned off because there is a problem with the ABS. You will not get it back on until the cause is determined and fixed which may be just a failed wheel speed sensor.
The brake warning has probably been triggered by the same failure that has caused the ABS warning light (since they came on together and bleeding the brakes should make no difference).
If the car sat for 2 months, no doubt the battery went flat. You have not mentioned anything about the battery but if your battery is in poor shape this can trigger warning lights in many cars especially the ABS (and stability control systems).
The best option is to have the vehicle scanned for fault codes that have been generated and there will be one or 2 if these warning lights are displayed. Scanning the ABS for codes will show up one or more issues and you can trace the problem from there. I think you will find the brake warning and ABS warning have been caused by the same fault.
In any event make sure you check the brake fluid level in the car and look for any external leaks of fluid that may have developed. Check the operation of your brakes to ensure they are working normally and that the brake pedal is not slowly dropping to the floor when you continue to apply pressure. Bleed the brakes if the brake fluid is 2 yrs old or more.
Dec 20, 2015 | Cars & Trucks
ABS light on with warning sound and brakes heavy. Brake pads are new
It sounds like the master cylinder may have failed, check for brake fluid leaks at wheels also vacuum line to the brake booster
Apr 27, 2014 | Mitsubishi Montero Cars & Trucks
ABS warning beeper
no reason you cant unplug it ? . i see your not too concerned with your safety ? what about other people families though ? we are talking brakes here.
Nov 21, 2013 | 2000 Volkswagen Beetle
My cruise control won't work and my brake light is on. The car is a 1994 Toyota Camry. Thank you.
Your brakes warning light or your actual brake lights? If it is your warning light that can come Monday if you're park break is on or slightly on or the switch that says that it is on is faulty, in which case it may tell your cruise control to turn off. If your brake lights stay on there's something pul to you about your switch by the pedal as your cruise will not work when you hit the bricks and this will be perceived as you hitting the brakes. A break warning light will also, come on if your brake fluid is low.
Jun 07, 2010 | 1994 Toyota Camry
TEKONSHA BRAKES
if your brake lights are coming on when they want it could be the brake pedal switch it could also be a short in the controller
Oct 18, 2008 | 1995 Nissan Pathfinder
Trailer brake control
I use a AccuPower Pod brake controller, by Tekonsha. It is small, and easily adjusted. Most RV retailers can install them.
Jul 04, 2008 | Computers & Internet
Electrical Supplies Logo
383 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
