Question about Toshiba Satellite A105 Notebook
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
Hi all, my Acer Aspire 5570Z Laptop displays the following error at startup.
PhoenixBIOS 4.0 Release 6.1
Copyright 1985-2004 Phoenix Technologies Ltd.
All Rights Reserved
ERROR
ERROR
Bus:0A, Device:09, Function:01
ERROR
Resource Conflict - PCI on Mass Storage Controller on Motherboard
Bus:0A, Device:09, Function:02
ERROR
Bus:0A, Device:09, Function:03
Press to resume, to Setup
Pressing F1 allows Windows to load fine. Device Manager reports that the CARDREADER is at Bus10 (which is 0A in hexadecimal) so maybe the cardreader has some damage. I'd like to know if I can fix this, by opening the laptop, pulling out the cardreader and seeing if there's any bent or broken wires or metal. Otherwise I'd like to remove the cardreader altogether in the hope that the "press f1" page doesn't keep appearing every time I turn on the computer or restart.
  • ghostmut
    ghostmut Jul 19, 2008
    Tried default bios settings as you suggested, same error. Also tried various bios versions from acer website, and Vista, XP, and no operating systems present on hard drive .. I'm gonna open up laptop right now to see if I can fix cardreader (?) or remove it hoping the error message will not appear (?) The 5 in 1 cardreader brand is texas instruments, and I believe the pcmcia card slot is physically part of the device.
  • sanju939 Sep 04, 2008
    Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM problem
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Posted on Sep 01, 2008
  • 3,940 Answers
Try booting to the system setup (F2 most likely at boot) and resetting the BIOS DEFAULTS, save and exit
Posted on Jul 19, 2008
    Sergeant:
  • 180 Answers
كلام عملى جدا
Posted on Apr 16, 2010
  • 2 more comments
  • muhammad mamdoh
    muhammad mamdoh Apr 16, 2010
    i like yhis sugestion
  • muhammad mamdoh
    muhammad mamdoh Apr 26, 2010
    I have the same fault in Exploration of the Toshiba laptop I thought that the problem in the BIOS I have to change the BIOS of the motherboard from another device is identical to him, but did not change the message. The device to restart the work or entering the BIOS. Does not enter the Hard disk or the CD-ROM or slots of the USPI. Found that the problem in the cache on the motherboard BIOS that is stored clothing and replied to her and when I unloaded as follows.
    Remove the keyboard from the device you will be proud of card Remove the card below it you will notice two signs**88
    When you close with some of these points and left it for 24 hours you run the laptop did not show the message again, but this may have eliminated the possibility of a password again from the BIOS as the storage room and place one empty one.
  • muhammad mamdoh
    muhammad mamdoh Apr 28, 2010
  • muhammad mamdoh
    muhammad mamdoh May 07, 2013
    I had forgotten that less that he must remove the battery time on the board in order can not BIOS to remember the main problem in the slide-causing malfunction and which we can overcome that property in the program built, which is used by the BIOS to lose parts where there is a flaw, and it allows for a follow-up operation
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
Nov 25, 2008 | Acer Aspire 5100-5033 Notebook
Hi :) plese help
remove all external devices and try again does it beep at all?
Jan 03, 2008 | HP OmniBook XE3 Notebook
Toshiba Satellite A105 Notebook Logo
13,000 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
