Question about Hoover Washing Machines
I have a hoover performa 1100 and twice this year (2nd time last night, 1st time 2 months ago), it has exploded with a loud bang followed by a burning/singed smell and smoke. It is 8 years old. It has happened when I leave it powered on after the wash say for 10 minutes or longer (without collecting the washing).
  • scopsm Jul 19, 2008
    So is it time to get a new washing machine which I am thinking of doing in case this one goes on fire the next time?
  • 41 Answers
Mains filter capacitor usually goes with a bang and puff of smoke it is usually located near to where the mains cable enters the machine fixed to the rear panel by a nut the main cable is connected directly to it then the cables from it feed power to the machine. the capacitor is usually round in shape and has four connections onto it
Posted on Jul 19, 2008
  • ken pawson Jul 19, 2008
    the part to repair it is relatively inexpensive (under £20) and can be obtained from any good washing machine repair shop
Spinbrush is very loud, barely sprays, spraks flew out the side. It is only 6 months old.
Hope you kept your receipt! That's a warranty item. Your motor is making the sparks. Go to hoovers website find the nearest service center and take the machine and your receipt to them. You'll get a new motor, installed, at no charge because they have a 1 year warranty.
Jan 18, 2013 | Hoover Steam Vac Dual V w/ SpinScrub...
Toshiba 52hm95 lamp breaks after only weeks of use
It is as far as the set is concerned, it sees the lamp not on.
Most likely cause would be the lamp ballast that drives the lamp.
Dec 20, 2012 | Toshiba 52HM95 52" HDTV Projection...
My samsung microwave oven is pouring out smoke when in use it made loud pop or bang the other night when using it and when i open the door gray smoke came poring out
Sounds like some metallic object was in the microwave oven when it made a loud bang. Was there a piece of aluminum foil or any metallic object inside when it happened? or the container you used, does it have some metallic linings or decorations?
Nov 05, 2012 | Samsung Stainless Steel 1.7 Cu Ft Over The...
Maytag Performa is walking and banging with even loaded lightweight tub (no towels or heavy items). It is so loud it is about to explode. Hear could be a snubber ring. Service fee is enormous and part is...
Hello, Thank You for using FixYa. I will be helping you today.Look to make sure none of the springs around the base broke and make sure the milk stool (tub support) Is not cracked.I have only had to change maybe one snubber in fifteen years.See more broken springs and cracked milk stools.When you grab the tub support at the bottom it should glide around on the center snubber,not real loose firm but moving.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Maytag Performa PAV3200
I have a Servi-star 40 Gal. electric SN# SS 0496B15258, How old is this unit? Thanks, Jim
http://www.buyerschoiceinspections.com/water-heater-ages
There seem to be 2 possible answers: Servi-star vs Servistar
Answer #1: Servi-star by American
1st 2 digits are year, 2nd 2 digits are week
This means water heater was made year 2004, 96th week ....it seems wrong.
Answer #2: Servistar by Craftmaster
1st 2 digits are month, 2nd 2 digits are year
This would mean your water heater was made 4th month of 1996
Which answer is true? 6 years old or 14 years old
If tank had 12 year warranty and came with 2 anode rods, and you have good water, and no stray current on pipes, then tank can last 14 years.
If tank had 6 year warranty and came with one anode rod, and you have hard water and a water softener, and you never changed anode rod or drained tank, then 6 years is a long life for the tank.
Oct 07, 2010 | Rheem Water Heaters
Hoover performa 1100 ac110 not emptying
After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
Remove filter by unscrewing anti-clockwise.
Feb 06, 2010 | Hoover Washing Machines
Hoover performa 1200 bangs when spinning.
it sounds like you spider as broke you will need a new drum as they are not bolted on
Jun 21, 2009 | Kenmore 24872 Top Load Washer
How to work the hoover performa 1100 washer dryer
My Hoover Performa 1100 does not drain the water therefore it does not open. Can anyone help please?
May 15, 2009 | Washing Machines
Transmission
This is a possibilty. When the gear lube in the differential warms up and thins down alittle, there may be enough "Slop" or wear in the gears so when it shifts, it feels like a "Bang". Something like if you were driving a manual trans vehicle and you "Pop" the clutch. Have the ring and pinion gears check for excessive wear.
Another thing to look for are bad "U" joints. They can fool ya and give you false noises and vibrations.
Good Luck
Mar 04, 2009 | 1999 GMC Suburban
Evaporator Coil
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Sep 09, 2008 | Heating & Cooling
Washing Machines Logo
376 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
