Question about Hitachi Cameras
When I turn on the camera "media error" is displayed on the screen. The card is OK I have tested it in anoother camera. Hitachi hdc-1251e
  • runsimonrun Jul 19, 2008
    There is a set button but not an OK button. I tried it with the set button, but no joy.
    I have also tested another card in this camera and it workd fine.
  • 790 Answers
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Posted on Jul 19, 2008
Hitachi HDC-I49IEP how to delete pictures
Try formatting the card using the option in the camera itself. or take the card out and put in laptop / PC using the card reader and try formatting the card.
Apr 13, 2014 | Hitachi Cameras
Hdc-1209er screen failing can it be repaired
Roger, the LCD screen can be replaced and they are listed on E-bay under camera parts under your make and model camera.
Jan 16, 2013 | Hitachi Cameras
I recently purchased a hitachi 1251e and have put a 2gb sd card in and now i cant take any pictures and the screen shows "media error". please help me, what do i need to do??!!
Hello!!
Firstly switch off the camera.
Press and hold the ok button and turn the camera on and off for few times whilst keeping this button depressed .
Dec 02, 2010 | Hitachi Cameras
I have a Hitachi Camera HDC 1087E, using camera on holiday sudden says card error and now does not work. Why?
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 25, 2010 | Hitachi Cameras
How do i transfer photos from sd card to camera on my hitachi hdc 651e
1.Remove your SD card from the camera.
2.Insert it to your laptop card hole
3.If a window opens opens automatically then just drag and drop your photos to where you can find easily.
4.If a window does not open then click to My Computer
5. Find your SD card there.
6. Do the instruction number 3.
That is all.
Apr 02, 2010 | Hitachi i.mega HDC-401 Digital Camera
Hitachi Camcorder VM E220A - After load cassette "TAPE" error
There is a mode switch within the deck assembly that is probably dirty but not cleanable. I haven't repaired one of those for some years and am sure spares are no longer available for it. The 58 is V8 format and should be OK but may show similar symptoms due to age, in the future.
May 24, 2017 | Hitachi i.mega HDC-401 Digital Camera
Hi, Have purchased an Hitachi HDC-756E Camera but can't connect to my PC - message says " One of the USB devices attached to this computer has malfunctioned and Windows does not recognise it...
This camera uses SD memory cards - avoid connecting the camera to the PC - it only causes problems - get a card reader for $7
Get a SD card reader, take the memory card out of the camera and transfer the images by using the reader
-it's faster
-it's more reliable
- you don't eat up camera batetry life
-you can continue shooting with another card
- you can recharge while downloading pictures
May 01, 2008 | Cameras
Hitachi HDC-530E
can anyone solve the problem on our Hitachi HDC-530E digital camera? We constantly and most annoyingly get only black and white pictures despite re-setting the camera dozens of times.
Oct 27, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
176 people viewed this question
Top Hitachi Cameras Experts
Parshiv Luthra
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
