Question about Black & Decker Spacemaker 10-Cup Coffee Maker
R-dcr 902t is a total pc of junk. it broke in 1 day. 90 day money back or a better coffee brewer
You have a plan that will cost me money to fix someones pc of junk coffee maker, you have got to be kidding, what planet are you from
Posted on Jul 20, 2008
I need a water valve for a B40 Keurig. One of the two in my unit is leaking.
Hi, You may be better off to buy a junk machine on Ebay...
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
Aug 29, 2011 | Coffee Makers & Espresso Machines
My Coffee maker is not brewing, and the screen says de-scale. I don't know what to do, I remove the water container, turned it off and back on. I will appreciate your help, thanks Andrea
Step 1: Plug Brewer in and turn power "ON".
Step 2: Pour approximately 64 oz of the vinegar into the Brewer until 4 beeps signal the tank is full.
Step 3: Wait about 6 - 8 minutes for the vinegar to heat up and the green "READY" light to go on.
Step 4: Place a ceramic mug in the Drip Tray and run a brew cycle. DO NOT USE A K-CUP...just press the Brew button.
Step 5: Repeat the brew process 4 or 5 times pouring the contents of the mug back into the Brewer after each cycle.
Step 6: Now let the Brewer stand for 4 hours while still on.
Step 7: Place a ceramic mug on the Drip Tray and run 4 brew cycles, pouring the contents of the mug into the sink after each cycle.
Step 8: Turn the brewer off, let the remaining vinegar cool, and drain the brewer as instructed above.
CAUTION: Vinegar may still be hot. Remember to replace the Drain Cap.
c. RINSE
Step 1: Fill the brewer with hot tap water.
Step 2: Power up brewer.
Step 3: Wait about 6-8 minutes for the water to heat up and the Green "Ready" Light to go on.
Step 4: Place a ceramic mug on the Drip Tray and run a brew cycle.
Step 5: Repeat brew process 4 times for a total of 5 cycles.
Step 6: Drain the brewer as instructed above.
CAUTION: Water may be hot. Remember to replace the Drain Cap.
Step 7: You may need to rinse again to eliminate any residual taste.
http://www.keurig.com/Customer-Service/Brewer-Registration-And-Support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions_04_30_2004.ashx
Jun 06, 2011 | Keurig Platinum B70 Coffee Maker
How long does it normally take to descale a Keurig?
Hi, The longer you can let the solution in the unit the better job it will do...it may also take few tries to get it completely cleaned...
Check out this tip about how to descale your Keurig coffee brewer
How toDescale your Keurig Coffee Brewer
heatman101
May 01, 2011 | Keurig Ultra B50 1-Cup Coffee Maker
How can the length of the garden hose effect the amount of work done ?
Digital Satellite Coffee Brew Centers Model: BC302E-IT Twin
The Operator's Manual for your product can be found here:
http://www.grindmaster.com/docs/Ni90A-BC-IT-MAN.pdf
WATER HOOK UP
The National Sanitation Foundation (NSF) requires the following for NSF approved installation:
1. A quick disconnect water connection or enough extra coiled tubing (at least 2x the depth of the unit) so that the Brewer can be moved for cleaning underneath.
2. An approved flow-back prevention device such as a double check valve to be installed between Brewer and water supply.
WATER CONNECTION
The Brewer comes equipped with a ¼ inch compression water inlet fitting located in the back. Use a ¼ inch copper tubing to connect the Brewer to a cold water supply. Water pressure should be: 20 PSI min. to 90 PSI max. An external shut-off valve and a water filtering system with a charcoal filter are highly recommended. Turn water supply on and check for leaks at the water inlet connections, tighten compression fitting if necessary.
Hook-up using a garden hose would not be recommended; if the hose is too long you may not meet the minimum required pressure and will have difficulty filling the machine.
Feb 16, 2011 | Cecilware Coffee Brew Center wWater Tap...
I have the platinum Series Quiet Brewer (cinnamon color) that I bought 3-11-10 on QVC. About 1 months ago it started shuting off after filling one cup of coffee, it fills the same amount of coffee no...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
sdfdf
sfsd
fsdf
ds
Dec 23, 2010 | Keurig Platinum B70 Coffee Maker
"not ready" frozen on screen
Try to unplug and plug back in..plus follow the below
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
Dec 23, 2010 | Keurig B60 Coffee Maker
I have a Keurig B66, the reservoir water gets heated but then comes back into the water reservoir from the top vent tube. The water coming back into the reservoir is very hot; almost no water goes into the...
Try this first....
Dec 22, 2010 | Keurig B60 Coffee Maker
I have a Bunn CWTF15. Water does not fill the coffee pot full anymore. Is there a float that needs to be adjusted? Would descaling help this problem? Thank you.
If u haven't cleaned it out using 3/4 vinegar to 1/4 water, some times this will happen. after running this thru ur coffee maker, (u won't believe the junk that comes out), then run full pots of water to rinse out (2x's). This should help it perform better.
Sep 12, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
Jan 11, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Black & Decker Spacemaker  10-Cup Coffee Maker Logo
54 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
