FixYa.com
Tags:
Gateway GT5220 PC Desktop
Starting
posted by coop123 on Jul 19, 2008
my pc when starting shuts down windows says there has been a problem detected and says STOP oxoooooo73 (oxoooooo5, ox8o58fba1, oxf79cd1e4, oxf79cceeo) help please
Comment by coop123, posted on Jul 19, 2008
its a gateway gt5238e media center desktop
guess you cant help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
Dageezer
Rank:Guru Guru
Rating: 87%, 218 votes
The error you are receiving is indicating that the Windows Operating System settings cannot be located on your hard drive to complete the loading of Windows. There are several possible causes, starting with a hardware failure of the hard drive. Others could involve a corruption of the registry due to unknown causes.
The first thing to try is the F8 menu during boot (Start tapping F8 when you see the Gateway Splash Screen) and try to boot to the SAFE MODE. If that fails, boot to F8 again and select the Last Known Good option on the menu.
If that fails to boot to windows, then recovering the OS doesn't look to optimistic. Other options are bootcfg /rebuild to check and see if the boot.ini file is corrupted
http://support.microsoft.com/kb/291980/en-us
and if that fails I suggest running diagnostics on the hard drive.
A longer shot at recovering the OS is what is known as a HIVE copy in the recovery console. This is essentially a system restore done manually in the recovery console, and is the last ditch effort before reinstalling Windows. Steps for Hive copy are at the bottom of this post:
http://dellcommunity.com/supportforums/board/message?board.id=dim_other&thread.id=210955
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PC Desktops problems?
PC Desktops
I just bought this disk
I just bought this disk a week... Answer This...
PC Desktops
when i turn on my
when i turn on my systemax... Answer This...
i tried to put my google...
when i go check eveything it... Answer This...
pc windows 98
cu scot de pe net ,drivers... Answer This...
Gateway PC
How can I remove the Power... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
