Question about Canon PowerShot A95 Digital Camera
Camera won't turn on with fully charged batteries in it.
I have placed two different sets of fully charged batteries (NiMH) in my camera, which have enough power now to operate a cassette player, and the camera won't turn on. The green light flashes for a split second and that's it.
Recently, I have able to operate the camera for decreasing amounts of time with the batteries...taking just a few pictures would cause the "low battery" icon to come up on the screen.
  • sjkntally Jul 19, 2008
    Yes, that was the problem. I used a small screwdriver to bend one of the battery contacts that looked a little lower than the others. Camera starts right up now! Thanks so much!
    Genius:
  • 3,422 Answers
First you check ur battery power still constant if not check ur memory card .Empty. ur memmory card through another card reader then on ur camera without putting MC.
Posted on Jul 19, 2008
  • Priya darshan Jul 19, 2008
    Polish the terminals with
    a dry cloth and make sure the terminals are clean. If the terminals are
    covered with oil from your skin or similar matter, this may cause poor
    contact and power may not be fully supplied to the camera.
    Also,
    polish the battery charger terminals with a dry cloth before charging
    the battery. If the terminals are covered with oil from your skin or
    similar matter, this may cause poor contact and the battery may not be
    fully charged.
    If the lens does not extend then it is possible that it has become
    jammed. Sometimes this can cause the camera to sense an error and shut
    itself down immediately after powering on.
    There are other
    explanations for the behavior, but if the lens does not move this is
    the most likely cause. If the lens does extend but then the camera
    shuts right back off it is possible that an inner component such as the
    focusing element is not functioning properly.
    Goodluck,
    Please don't forget to rate or accept the solution
    Brigadier General:
  • 6,966 Answers
try cleaning the battery contacts. At certain instances it may be necessary to scrape them or to partially bend them that they provide a bit more pressure towards the battery terminals.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Red battery light even with new batteries - then shuts down
Your camera can work with 2 AA sized batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period.
Always charge sets of batteries together.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
AA manganese (Zinc-Carbon) batteries and NiCd rechargeable batteries cannot be used with this camera.
If you are sure you have good batteries, also check if all contacts are clean and shiny. No oxidation is allowed. To clean contacts never use sharp tools. They can damage the camera forever.
Eventually clean contacts with a cotton swap or a dry cloth.
Also check if no debris is in the battery compartment. Just a little pice of paper can spoil all the (camera) fun.
Just to make sure, try some other batteries, then the ones you are sure of, they are fully charged. Perhaps, next time you are less convinced.
Feb 24, 2014 | FUJIFILM FinePix AV130 Compact Digital...
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
Camera won't turn on to take pictures~
This is a common problem related to batteries. Use 2100mA or higer batteries fully charge batteries. This problem occurs when you use alkaline batteries or faulty NiMH batteries. To solve the problem try with new fully charged NiMH batteries.
May 14, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
My batteries wont stay charged does it come with an alternate charge source?
Try NiMH Batteries then adjust the settings in your camera to NiMH...Amazing difference!
Feb 21, 2010 | Canon PowerShot S2 IS Digital Camera
Everytime I put batteries in it just beeps like the batteries are low and won't turn on
I had that problem. The camera can distinguish between NiMH and Alcaline batteries. Your camera is probably set to the wrong type.
Put in fully charged NiMH batteries OR alcaline batteries, check which doesn't cause beeping. After switching on the camera search for the menu where you can change the battery type and change it to that type you want to use. Consult the manual if you cannot find the option, it's under the setup icon.
Feb 11, 2010 | Polaroid i735 Digital Camera
Canon Powershot A470 - asks to 'change battery' every time it is turned on, then turns off immediately. This is so even when new, fully charged batteries (different brands, rechargeable, non-rechargeable)...
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
Jan 08, 2010 | Canon PowerShot A470 Digital Camera
Camera shows battery exhausted with new batteries.
You should be using Nickel metal Hydride batteries (NiMH). Do not use Nickel Cadmuim(NiCd), Zinc carbon or alkaline.
Mar 12, 2009 | Nikon Coolpix L1 Digital Camera
Battery Low with NiMH (won't turn on) OK with Alkaline
Not the camera obviously - works OK Replace the NiMah batteries- get several sets and keep one set in the bag charged with one set in the camera. You may be able to 'refresh' the original batteries by putting them into a small flashlight and running them until the bulb goes out. This discharges them completely- then recharge. It is said batteries have a 'memory' so that a battery that is down say 50% and recharged will only recharge that 50% and the other 50% is lost for use. So you have to flatten the batteries completely
May 29, 2007 | Samsung Digimax A7 Digital Camera
Battery problem when on computer
The cable connector on the *istD looks fairly flimsy to me and I am willing to bet it is not designed nor will it last as many insertion cycles as the CF card socket, also the CF card is much more tightly aligned less chance to damage contacts by inserting at an angle, near impossible. Any card reader is faster that using the cable, the cable is only USB1. You say you are lazy, but gee whiz you must be vey patient waiting for images to download via the cable at USB1 rates.
Sep 08, 2005 | Pentax *ist D Digital Camera
Canon PowerShot A95 Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
