I WANT TO KNOW HOW TO BUILD THEM MY SELF. - Computers & Internet
  • 3,940 Answers
I found several tutorials on Goolge searching for "How to build your own PC" I looked at several and here is one that looked pretty good.
http://www.daileyint.com/build/
Posted on Jul 19, 2008
I have a whirlpool refrigerator model #GT15HTYMQ81
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The defrost timer The defrost thermostat (also called the bi-metal switch)
Aug 21, 2011 | Whirlpool GT1SHTXM Top Freezer...
Not cooling and freezing properly
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Mar 29, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I think my evaporator fan is out everything in fridge is warm to touch and ice is built up on freezer wall at rear of freezer and ice cubes will not freeze solid.also do not hear fan running any more
Hi there
I have found some stuff for you to read hope this helps you. Let me know how it goes.
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Thank you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | LG LRBN22514ST Bottom Freezer Refrigerator
Kenmore Elite ice maker doesn't work
Evaporator coils
If it still exists then there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Sep 25, 2009 | Kenmore Refrigerators
Temp only gets down to 39 degrees. The door seems to be shutting correctly. I hear the door suction being applied. It looks clean around the door. It's a Frigidaire stand up
Hi, Is this a self defrosting freezer? If so, check and see if there is any frost build up on the rear evaporator panel. Check and see if there is an ice build up around the defrost drain. Couple of ideas for you. Please let me know if you find either of those or if I can asssist you further.
Thanks
Vic
May 11, 2009 | Freezers
Just wanna know how to set correctly the valve setting for galant mpi 1992. is it done manually or by machine shop. thanks
they are probably hydraulic valves and are self adjusting.  Very few manufacturers build engines with adjustable valves.
Mar 11, 2009 | 1992 Mitsubishi Galant
I NEED TO KNOW IF IT IS SAFE TO RUN MY SELF CLEANING OVEN WITH MYSELF AND PETS IN THE HOUSE. THANK YOU IN ADVANCE IF YOU CAN ANSWER THIS QUESTION.
The general answer is yes, however if there is a lot of build up in the oven the self clean cycle may result in irritating smokey fumes. It's always best to clean the oven before there is a heavy build up, and at a time when you can open a window or two if the fumes start to bother you. If there is a build up on the floor of your oven now, you can try using a plastic spatula to scrape off some of the real heavy stuff before self cleaning. This should be a FixYa for you and your cats. Thanks.
Dec 07, 2008 | Kitchen Ranges
Taking Video
there should be a program build in to windows XP called Movie Maker, you can use that to record a video of your self. If movie maker is not installed you can go to microsoft's website and download it for free. Thank you.
Nov 26, 2008 | Intel Pro Video PC Camera CS431 Webcam
I don't know how to set my self cleaning oven to clean.
There's no such setting because there's no build-up of cooking residue - hence self-cleaning. You will need to clean the trays though because it's impossible to make them self-cleaning.
Nov 22, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Atlas La Stella double oven
Hello Roland,
happy to help you out!
You must clean by way of wiping excess spills and materials dripped or spilled before self clean is operated. Or there will be smoke even during the self clean process!
Also do not wait till there is build up galore to self clean your oven!
If you spill or splatted and drip in the oven that day,
start the self clean after you do the dinner dishes!
More info can be found int he owners manual!
Aug 24, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
