Question about LG Washing Machines
LG INTELOWASHER WD80100TP DOOR SEAL
THE DOOR SEAL IS BROKEN, I CAN GET THE FIRST METAL SPRING LOADED SEAL RING HOLDER OFF BUT THE PLASTIC RING TO HOLD THE SEAL IN PLACE BEHIND IS IMPOSSIBLE TO GET OUT
HOW DO I REPLACE THE SEAL?
WHERE CAN I GET THE SEAL?
I LIVE IN FRANCE BUT PURCHASED THE MACHINE IN SOUTH AFRICA 4 YEARS AGO SO I DO NOT KNOW HOW TO GET SPARES HERE
aborcass
  • 2651 Answers
SOURCE: How to replace the door bellows seal ?
did hte rear clamp come off or just the front spring. assuming its just front spring.carefully reinstall the boot over the front lip assy . easy enough!!here comes the fun!! the spring itself goes to the bottom of the rim.So hang the wire over the top of bellow and feed into the lip evenly as you go down both sides as soon as you get your hands to the 9oclock and 3 oclock positon I then change grip on the spring (use the tips of my fingers palms facing front assy and strech whole pushing down and in. I used to find small spring style clamps would work great for holding the wire in place till it would "pop" into place. a third hand is also very useful to hold in place .
Posted on Mar 12, 2008
SOURCE: replace rubber seal on my zanussi washing maching
Found it impossible. After 30min I tried the washing up liquid trick and I got the rubber seal on in 1 min. Getting the spring on was another story, but managed in the end.
Posted on Jun 15, 2008
jsrock516
  • 5911 Answers
SOURCE: How do you install rubber door seal and the metal
The following link explains step-by-step how to install a door bellow on a Whirlpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip!
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Posted on Oct 28, 2009
SOURCE: Lg WD8013f frnt load washer seal broken
the cycle selection button on my wd 8013 f doesnt work all that good how do i fix it ? reg bob
Posted on Aug 22, 2010
ginko
  • 19396 Answers
SOURCE: when pulling out heavy load
Hi.
I uploaded the full service manual at the link below. The schematic views are in the last pages of the manual.
Try first:Click here to start download..
If that does not work, proceed from: WD-1049C Service Manual
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 09, 2010
Dishwasher door no longer spring loaded. If standing too close, it if hurt your legs. it will stay closed, but no spring to load the weight of the door when opening.
In most cases, there are 2 springs inside the door, one right and one left.
Either a spring has broken, or the metal; holder that holds the end of the spring has.
That spring should be available from "searspartsdirect" if you will type your model number into their web-site.
God bless your efforts.
Mar 19, 2018 | Dishwashers
When moving a whirlpool washing machine (Model AWM 1000) a large thin metal ring (spring-loaded at one end) came out. Where does it go to refit it and how do I refit it? On the machine there's a groove...
It goes to the outer lip of the door opening where the groove is to secure the door gasket. It definitely serve such purpose, not for nothing.
Oct 13, 2010 | Washing Machines
The drum got loose because the one of the top drum springs got unhooked. The spring holder on the plastic drum cover is broken. It was noticed in time and turned off. So it seems that nothing else is...
will the plastic ring in the second ring move to the other ring . the danger is if you put the spring in the second ring the drum may not be line up straight when you look from the top (the motor may be further back) causing the motor and back to rub on the back plate when loaded might be better to drill new hole ?
Feb 11, 2010 | AEG Lavamat 88840 Front Load Washer
Replace LG washing machine seal
Hi
When you open the machine door, you will see a manufacturer's badge. Record the model number and call around to order the door seal from your local parts vendors. Have the replacement seal ready when you are changing the seal. If you remove the seal and then go to source it, then you might not remember how it was put on initially.
To replace door seal, First turn off machine and unplug from its power source.
Next remove top lid. Two screws in the back of the top lid and you can slide the lid back and up to remove. See if you have a clear view of the door seal from above the machine and see how it is joined to the drum mouth. There would be a metal ring holding it in place. Locate the screw which tightens it and unscrew it to loosen the ring.
Next the wire ring which you have already seen on the front of the seal needs to be removed. These are normally spring loaded. Feel around the ring until you get to the spring tensioner. With a flat screw driver, stretch the spring to pull the ring out from around the seal.
Now observe how the door seal is clipped around the front panel of the machine. The seal has a groove which fits snug agains the rim of the front panel. You can now remove the seal by pulling around the edge.
Now go back to the top of the machine and do a similar thing to remove the seal from around the drum. Make sure you observe how it had fitted on originally, and also observe if there are any differences between the top and bottom of the seal where it sits on the door. There normally is a difference.
When replacing the seal in the reverse manner, make sure you fit the seal correctly around the lips of the drum and the front panel. make sure you also correctly tighten and refit the rings to hold the seal in place.
Once you have finished run a couple of quick cycles without cloths, to make sure there are no leaks and that the seal is fitted properly.
Good luck.
Ash
Nov 09, 2009 | LG Washing Machines
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Wm1832cw door seal re-installation
If you haven't gotten a solution yet, I did this myself. It is pretty hard to remove the spring that is holding the gasket in place. Once you do that, just replace the gasket and reattach the ring w/spring.
Sep 11, 2008 | LG WM-1832C Front Load Washer
How do I replace my boot gasket on my Bosch Nexxt washer?
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Aug 09, 2008 | Bosch Washing Machines
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Rubber sean and wire spring came off
Hi
Spring should be a the 6 o'clock . you may need someones help have some hold the wire on at 15 and 45 ... when you pull the spring apart and slided it under the bellows. be careful as the spring can fly off. good luck and keep trying...
Apr 05, 2008 | Bosch WFR 145 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
96 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
