Question about Gateway GT5220 PC Desktop
Starting problem pc will not go ti normal screen it asks a problem has been detected and windows has been shut down. on bottom is 0x0000007E
  • coop123 Jul 19, 2008
    its a gateway gt5238e
    Scholar:
  • 174 Answers
Try to replace any new hardware installed or take the backup and format your system
Posted on Aug 19, 2008
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
I get a pop-up ballon that says "USB device not recognized"
How do I fix Error: TI-89 Detected, but could not get status with the TI-89
using the TI Connect software for Windows?
The Operating System (OS) will need to be updated on the TI-89 in order for the TI Connect™ software to detect the status. Try the following procedure to install the OS from the TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC.
• Connect the TI Connectivity cable to the TI-89 and the computer.
• Do not start the TI Connect software.
• Download the TI-89 v2.09 OS onto the PC's desktop.
**Force TI-89 into "Boot screen" (See instructions below**
• "Press I to install..." ([ALPHA]. [ 9 ]).
• Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
• Follow the on-screen directions to install OS version 2.09.
The download should begin.
**Steps for Boot Screen:**
• Take one AAA battery out, press and hold down the Apps key while reinserting the battery to force device into the Boot Code screen.
• "Press I to install..." will appear.
Once the OS has completed installation, the TI Connect™ software will be able to detect the TI-89.
Mar 01, 2008 | Texas Instruments TI-89 Calculator
My Aspire x1200 turns on and acts like it wants to boot up, however, brings me to screen that asks if I want to launch startup repari, or start windows normaly. When I try the Repair mode it does nothing...
You will need a recovery cd to boot your pc and you can download that recovery cd from following link
Windows Vista Recovery Disc Download — The NeoSmart Files
once you download the file,just burn it to cd and boot your computer with this cd and it will be fine
Jul 20, 2010 | Acer AX1200-B1792A PC Desktop
How do i fix blue scree error tha reads stop:0x0000007E
is this a recurring problem. There isn't much you can do, usually a software crash causes this,
maybe defrag the computer, uninstall any unneccary software, run a virus scan, etc. Sometimes it just happens, if it happening all the time, there maybe a hardware problem, or you may need to restore to factory settings.
Jan 06, 2010 | Dell Dimension E310 PC Desktop
U must help me
It could be either a corrupted ntsldr file in which case you would need to reinstall the operating system, or it could be that its getting too hot and its shutting off because of the heat
Nov 18, 2009 | HP Pavilion dv6000z Notebook
Ti 89 detected but couldn't get status
Here is what the FAQ and Knowledge Base area of the TI site has to say about the problem you are having. Hope it helps.
How do I correct the error message "TI-83 Plus or TI-89 detected, but could not get status" using the TI Connect software for Windows®?
The Operating System (OS) will need to be updated on the TI-83 Plus family or TI-89 calculator in order for the TI Connect software to detect the status. Try the following procedure to install the OS from the TI-83 Plus and TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC.
If using a TI-89 calculator:
• Connect the TI Connectivity cable to the TI-89 calculator and the computer.
**Force the TI-89 into the "Boot screen" (see instructions below)**
• "Press I to install..." (press the [9] key).
• Take one AAA battery out, press and hold down the [APPS] key while reinserting the battery to force device into the Boot Code screen.
Once the OS has completed installation, the TI Connect software will be able to detect the TI-89.
Oct 31, 2009 | Texas Instruments TI-89 Calculator
Balance - Blue Screen during shut down stop error 0X0000007E
check your hardware settings it could be the codes for the hardware that cannot recognize of your systems. it could be change with the wrong specs. if you cannor configure it out. you better set the bios configuration to default setting and try to repair the system using your operating system cd installer. thanks
May 11, 2009 | Computers & Internet
After loading Window service pack 3 update, comes up blue screen
press f8 and go to safe mode and delete service pack 3. sp3 is known for problems
Sep 23, 2008 | Dell Dimension™ B110 PC Desktop
Gateway GT5220 PC Desktop Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
