Question about AOpen AX4B-533 Motherboard
SATA HDD MY MOTHERBORD NOT recognized SATA HDD During the initial installation of Windows, I press F6 BUT STILL NOT WORKING MODEL ( WD 1600 AAJS )
  • 101 Answers
If the motherboard has VIA chipset (older model), that was created when there was only SATA drives, it might not work with the newer SATA 2 hard drives. WD SATA 2 drives can be jumpered on pins 5&6 to 'slow' data rate. Check Wikipedia for "Sata" also.
Posted on Nov 18, 2008
  • 2,427 Answers
You need to install the drivers for it when loading windows,,
you are on the right track by pressing F6 however you need to have the FLOPPY DISK that came with your mainboard in the floppy drive..
If you dont have the diskette then ,, the drivers are located on the mainboard cd,, its in the sata / raid folder, there should be a text document in there with the insttructions on creating a floppy with the driver files you will need.
Posted on Jul 20, 2008
Hello, my main board is asus p4p800-vm running xp home with sp3 upgrade with ide hdd's and is running well. i bought 2 new sata hdd's because the board has 2 sata ports, i set the bios to auto to see the...
Windows will not see them because you need to download the SATA drivers for the motherboard from the Asus site.
Download and install to a floppy or USB (advise the latter)
Install windows,and you will get a "press f6 if you want to install a raid device ..."
Press F6 and hopefully, windows will find the drivers, highlight the ones it wants.. the rest should be simple
Jan 06, 2011 | ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/...
Windows won't recognize the HDD in my Dell XPS 400.
hawkdawg
In regards to installing your new harddrive if you are installed a SATA drive the issue is that not all versions of Windows has SATA drives native on the Windows install CD. So during the first part of the install you will need to press F6 to load the SATA drivers of the driver CD. If you do not have it you can download the drivers from support.dell.com
Let me know if you have any more problems or questions
Issken
Apr 13, 2010 | Dell XPS 400 PC Desktop
I cannot configure a SATA RAID 1 to mirror two WD HDD 1 TB
You sure you installed the ASUS RAID drivers when you installed Windows? Ya need to get the drivers off the ASUS disk, transfer them to a floppy, hit F6 when windows tells you to (during windows install...you only have a second or 2 to see the message!)) and use the floppy to install them. Might take a few tries to get it right.
Dec 26, 2009 | ASUS P5GD2 Deluxe Motherboard
Sata drive is not recognized by os during new install
When installing XP or Vista you get the option to load third party drivers for unknown devices. I think it's F6 just after the start of any version of Windows, once you press this you will have to supply the drivers for the Windows installation. This will make Windows recognise the hdd from then on.
Aug 18, 2009 | Gateway MT6821 Notebook
Windows xp will not recognize my seagate barracuda 7200.10 although it is recognized in the BIOS. I pressed f6 during setup and it is asking about the Manufacturer-suplied hardware support disk. Where...
If you have one HDD set it to master with your jumper settings. Try again. If No go than change the cable connector. If SATA HDD than change the connector on the MOBO try another connector. Restart. If still no go than write back
Jul 30, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Asus P4S800D-X mobo and sata hdd problem
I believe you need to load in the SiS 180 RAID controller for this MOBO during the Windows Install.
Do this by loading the driver onto a floppy and pressing F6 when told to do so by the windows install.
Mar 20, 2009 | ASUS P4S800D-X Motherboard
Hard disk drive not deteted during windows installation
This problem arises due to a missing driver in windows installation. download your specific driver and copy it to a floppy drive. Then start the windows setup. As the setup loads it will ask "Press F6 to load a SATA RAID driver".Press F6 and insert the floppy into Floppy disk drive.
And continue the setup...
Jul 16, 2008 | Computers & Internet
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Cant find my SATA HDD
Yes - find the chipset for the motherboard - go on intel website for that chipset - download the utility for F6 use [sata driver or raid controller] put these files on floppy or USB key - boot motherboard and when it says press F6 to instal SCSI or other drivers press F6 - the software will ask where the files are - use the correct file and carry on running the windows installation. This time your sata hard drive will be recognised and you can complete loading windows.
Please rate my assistance - thank you.
Mar 21, 2008 | Soltek SL-75FRN2-RL Motherboard
No HDD Found on initial XP Install
Did you insert the sata driver disks when prompted in the first stages of installation? I think it's mentioned as scsi drivers.
Mar 04, 2007 | Mach Speed (S755) Motherboard
AOpen AX4B-533 Motherboard Logo
110 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
