Question about GE Washing Machines
I have a GE front load washer model # whdvh626fww. it keeps making alot of noise when in the spin cycle and the belt keeps coming off. at first I thougt it was out of balance but that was not it . when I opened the back panel to put the belt back on I noticed alot of black stuff around were the drive pulley attaches.
  • rickdeadman Jul 20, 2008
    Thanks for your help! Thats what I tought. 2 years old and looking at $500.00 to $600.00 repair parts and labor, the bearings are pressed into the drum. I'll see what GE customer relations will do? A new one is $699.00 at home depot were we got the first one for $764.15 something really isn't right.
  • Anonymous Mar 20, 2014
    Washer makes noise like its out of balance when spinning
I have a different suggestion based on my washer's similar problem. If the black stuff is powdery and localized at the back of the unit, more than likely the culprit is the drum pulley itself is warped, causing the belt to chafe against the drum. The black powder is rubber residue from the scraping of belt on plastic. No need to replace unit. New belt and new pulley run about $70 each.
Posted on Jan 13, 2009
  • 41 Answers
Drum bearings and water seal have failed usually confirmed as a rumbling noise when drum is spun by hand the black stuff is grease and wash water leaking from the bearings due to the failure of the water seal in front of the bearings
Posted on Jul 19, 2008
I have a GE front loader washer model # WHDVH626FWW inner drum making loud thumping noise while washing and spinning
check your owners manual for warranty on inner tub and seal warranty parts may be covered in some cases but labor may not be....
Jan 27, 2011 | Washing Machines
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Machine making a knocking noise during spin cycle. The drum shaft has alot of free play front to rear and I suspect that is where the problem resides.
If your machine is making louder than normal noise during spin it could be the failure of the basket. Mine is just under three years old and the basket became looser than normal in the tub. I diassembled the machine...a lot of work...and found the aluminum casting around the shaft and bolted to the basket had rotted away. It looks like it was attacked by the bleach since I had my water checked and its pH is fine. It is likely the root of the smell we have experienced with our clothes when they sit too long in the machine. I spoke with GE and they gladly agreed to replace the parts needed but it is a ton of work to install them. I plan to treat the new part with some zinc chromate if I can get some before the parts arrive. See the picture if it attached correctly.
cid:07d1be63-2d47-407a-89ca-6090b4131d58
Nov 16, 2009 | GE WSXH208A Front Load Washer
Washing machine won't turn back and forth
Most likely your drive belt has slipped off. Open up the back of teh washer and see if the drive belt has slipped off and ease it back on with a screwdriver.
Jun 29, 2009 | GE WSXH208A Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Washer making noise during spinning cycle.
why is my ge front load washer making a rumbling noise
Jan 06, 2009 | GE Washing Machines
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Spin cycle not working
Maybe the spring device that keeps the belt tight is not working properly. You need to make sure what ever it is that keeps that belt tight is working properly or not damaged. The belt is very important for the spin to work good. Match it up with your old belt. The old belt will be slightly longer because of being stretched over a period of time. Get your unit number and model number (or take the belt) and go to your nearest dealer and get the correct belt.
Dec 22, 2006 | GE WSXH208A Front Load Washer
Washing Machines Logo
445 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
