Question about Bosch Washing Machines
The top of the rubber door seal has come away from the wire that holds it in how can I put it back
  • 41 Answers
First remove the wire retainer (usually has a spring attached) then fold the rubber lip of the door seal back over the metal lip on the front of the machine when correclly positioned refit the retainer by starting at the recess where the spring sits and stetching it all around the seal making sure that it is sat in the groove where it fits, it is fairly easy to replacestarting from the spring and following around clockwise making sure that it is seated right as you reach the other end of the spring the spring will stretch allowing you to finish tucking the wire in and the spring should then tuck in to the recessed part of the seal
Posted on Jul 19, 2008
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Posted on Jul 23, 2013
Can the metal ring that retains the rubber door seal be replaced by a simple wire?
Hi,I have replaced these rubber seals,the front ring shouldnt give you much trouble its the inner one thats the pain,I woulnt use wire as the one thats on it is sprung loaded.
Ive also had to replace the door latch on a washing machine,what I did was take the top off and reach inside,maybe thats an option,or the other way is to put the machine on its side and go in through the bottom.
I hope this was some help,all the best.
Jul 16, 2015 | GE GFWH2400LWW Front Load Washer
My washer front load rubber at the door has pulled away and the wire with spring has come out. the rubber is not torn and i put it back in but i dont know were the wire gos
If you are referring to the wire hoop with a small spring, this is the front bellow clamp. The bellow is the rubber door seal. Around the perimeter of the seal where it attaches to the door frame, is a small groove in the rubber. Make sure the rubber bellow is properly seated around the door frame opening, then the wire hoop inserts into the groove in the rubber to hold the front of the bellow affixed to the door frame. Without it and the bellow will eventually come loose and the washer will leak. To reinstall, just follow these steps:
1. Make sure the bellow is firmly seated all the way around the perimeter of the door frame.
2. Begin inserting the wire hoop into the groove, starting at the twelve o' clock position.
3. Work your way around the four and eight o'clock positions. While maintaining some downward pressure to keep the hoop inserted in the groove, pull the spring apart and snap the wire hoop back in place.
A second set of hands may come in handy to hold the hoop in position to get it reseated. Make sure the wire hoop ends up at the 6 o'clock position when you are complete.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer with heavy items can contribute to premature wear on the bellow and can cause the clamps to come loose.
Dec 29, 2009 | Kenmore Elite 45986 Front Load Washer
How to replace seal between door and drum
1. Unplug from mains electricity.
2. Pull machine out from wall carefully.
3. Remove screws in top corners (that are holding down the top panel of the machine) at the back of machine.
4. Remove top panel of machine (slide it slightly in the direction of the back of the machine, it just lifts off).
5. Remove the detergent drawer (pull it right out and put it to the side)
6. Remove the two screws at the top of the gap where the detergent drawer goes in
7. Remove the two screws at the top, front of the machine
8. Now lift out the panel with the control dials on it (etc.). Careful here, you don’t have to disconnect all of them, you should just be able to put this to the side with all the wires still connected.
9. If the old door seal is still on (if not go to 10):
a. Look carefully at the arrangement of the rubber at the lip of the drum and the door rim (you’ll need to know so you can put the new one on)
b. The outer rim is sealed in by a circular wire linked by a small spring. It’s a bit tricky but you can unhook the spring from the wire (using a blunt knife to lever it out – careful not to damage the rubber) to remove it.
c. The inner rim is sealed with a larger circular spring. You can either lever this out with the same blunt knife, or just pull hard on the rubber to get it out, and the rubber off.
10. Now position the new rubber door seal between the drum and the door
11. Grip tight around the outside and inside of the rubber door seal and attach it to the lip of the drum. This is the trickiest bit, and seems impossible but it is doable. The key here is that once you have a bit of it on, the rest will slip on as you work around it the circle. Even at the bottom and sides where your hands can’t reach it should slip on nicely. It ain’t easy, give it time.
12. Now get the spring on the inner rim to seal it (again, not easy, give it time and muscle – you need 3 hands for this!)
13. Then attach the outer rim to the lip of the door rim, and hook the metal wire back in place with the little spring.
14. Put the panels and screws back in in the reverse order to how they came off/out. Make sure there’s no parts left over, ey!
15. There you go – plug it back in and run a test wash. Check for leaks
Oct 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Water leaks from a hole in the bottom of the drum. The hole looks as if it should be there
15. There you go – plug it back in and run a test wash. Check for leaks.
Oct 21, 2009 | Indesit WA 125 Front Load Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
Washing Machine Door seal replacement
Hi, I'm not familiar with your particular model, but there is most likely a very similar type of clamp holding the back end of the seal to the static part of the drum. It is most unlikely that you will need to take off the front cover as on most machines only the back and top are removable. You might need to unfold the rubber to get to see the wire which is holding it on. If it is the type of clamp with a screw-tightening device, it might be rusted up and a new one might be called for.
If the old seal is damaged there is nothing to be lost by cutting away some of it with scissors so you can see better what you are doing.
When you get to the stage of putting the new seal on, try lubricating it with a bit of washing up liquid or soap to allow it to slip properly onto the casing and rum, and try to avoid tightening up with a twist in it - the soap should help. Remember to put the new one on in the reverse order to the way you got the old one off.
Hope this helps you a bit more. D
Jul 18, 2008 | Washing Machines
How do you change the door 'gasket'??
This is a generic solution, so there may be very slight differences for your machine, but it should still work.
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until ot is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
Jan 19, 2008 | Hotpoint WMM65 Front Load Washer
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
How to replace rubber door seal
when you open the door you find a this wire clamp round the edge of the door seal, this just comes off with little force, this has to go back on obviously so don't bend it, the door seal just folds back on itself, the clamp on the drum end is often a large thin spring, and that also just pulls off, the seal then also comes away with a little pull, the new seal is fitted with the groove either side of the drum lip, then the spring is put back, take note how all is removed before working on it? the front of the seal is fitted then the wire, close the door to check a tight but easy fit, check for any leaks and correct fitting before leaving machine unattended any time, sound worse that what it actually is, if i have helped rate me,
Sep 16, 2007 | Bosch WFR 145 Front Load Washer
Washing Machines Logo
183 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
