If you moved it or changed anything at all, make sure that the speakers are plugged into the green jack and that they have power. If they have a volume knob, make sure it is turned up.
Next, on the bottom right of the screen, click the speaker icon on the taskbar. Make sure MUTE is not checked, and that the VOLUME control is turned up.
If you still have no sound, go to START>SETTINGS>CONTROL PANEL and open the SOUND icon. Check your settings there- if MUTE is checked on WAV, uncheck it and make sure the volume slider is turned up.
First right click my computer in the desktop then properties then hardware then device manager then expand the audio,vedio and game controller see wether the driver is installed properly if not installed it will show yellow question mark the reload the correct drives from the cd which you recived with your computer install the audio software and restart the system then in the taskbar you will see the speaker icon right click them click adjust audio properties in volume move the slisders to full on uncheck the mute then restart your computer
