Question about HP Compaq nc6000 Notebook
Not install windows xp in hp laptop
Xp install
    President:
  • 778 Answers
Enter your BIOS and make sure you set your boot order to CD ROM first, or at least to before your HD and on boot make sure to look for the prompt (only shows for a few seconds to press any key to boot from CD) and you should be good to go.
Let us know if this method fails so we can suggest other options.
Good luck.
Posted on Jul 19, 2008
  • 33 Answers
SOURCE: i want to install windows xp sp2
It's a relatively simply procedure, 1st download all of the necessary drivers for your laptop from Compaq's website under the support section. You'll want the drivers for Window's XP. Either burn these drivers to a CD or place them on a flash drive. Also if you already have documents or data on the laptop that you would like to keep you'll need to back that up as well to either a CD/DVD or a flash drive.
Next you'll need a Windows XP installer disk. Place the disk in your laptop and reboot. The system should prompt you, asking you if you'd like to boot off of the CD press any key. Hit any key and the computer should boot from the XP CD. The system will take a while as it loads up the installer shell. If the system does not boot from the CD you will need to go into the BIOS or CMOS and change the boot order for the computer to make the CDROM or DVD ROM the 1st boot device. The 1st prompt on the installer should be a license agreement, hit F8 to continue. The next steps will pretty much be up to you. Things like where you want to install windows XP, do you want to format the drive, etc. This sounds like your 1st install so you may want to leave everything as default. Windows should detect your Vista install and by default install it as a seperate installation allowing you to boot into either OS.
After the OS has prepared the hard disk and copied all files the computer will reboot and will boot into a installer kernel and will prompt you for even more selections. This process will take longer than the initial portion and most of these settings you can leave at default as well. When this part is complete the system will reboot again and your installation of XP should be complete.
When the system boots into windows it will ask you to create a user name, create a user name or multiple ones. Put in your driver CD or flash drive and proceed to restore your files and install your drivers. That's the revised version of it anyway.
Good Luck!
Posted on Jul 10, 2008
SOURCE: No audio device after installing windows xp?
SALU
Posted on Aug 23, 2008
  • 2692 Answers
SOURCE: how to install windows xp sp2 on hp 530 laptop
Place cd into drive.Keep pressing enter until the computer reads the cd.Follow the directions on the screen. That is all their is too it. How did you get an HP without an operating system having been installed? thsi is a windows disk, correct? Not a reinstall disk?Should work the same either way.  If it gives yuo an error or doesn;t work please tell us what happened and we will direct you more. Thanks
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3375953&submit.y=2&submit.x=7〈=en&cc=us
Posted on Jan 19, 2009
  • 14 Answers
SOURCE: how can I install Winxp on HP pavilion DV5 laptop ?
You're Hard Drive may be dead. If XP is starting to install and then it goes to the Blue Screen of Death, that's most likely your problem. There's a slight chance that you're power inverter has a fluctuating power level that is causing a disruption, but that's very unlikely. Have you done any tests with any boot CD's to check the hard drive's function?
Posted on Jun 09, 2009
SOURCE: Not installed os in my loptop
http://www.computerworld.com/s/article/9040318/FAQ_Giving_up_on_Vista_Here_s_how_to_downgrade_to_XP
http://www.computerworld.com/s/article/9108198/Microsoft_offers_free_Vista_to_XP_downgrade_help
Obviously, the most convenient way to downgrade is to do so without reformatting. In order to do that, you need to have a real retail CD of Windows XP. If all you have is a recovery disk that came with your computer, you’re not going to be able to do it this way. You will need to reformat.
To downgrade, use the following as a guide:
  1. Do a full backup of your current, Vista system. If something happens, you can always revert to the backup.
  2. Boot your computer off the Windows XP disc. Just pop the CD into the CD-ROM and reboot. If, for some reason, your computer boots without looking for the CD drive, you need to go into your system BIOS and change the boot order so that it checks for the CD drive during the boot process.
  3. When the computer asks to press the space bar to boot from the CD, do so.
  4. When Windows XP Setup starts up, press “R” to enter the recovery.
  5. If it asks you to choose a Windows installation, press a number and hit Enter. The likely number will be 1.
  6. If you get asked for an Administrator password, enter when asked. If you do not know it, you will need to abort and go back into Windows Vista to get your password.
  7. At the command prompt, we’re going to use the “fixboot” command. We’ll use the following commands in sequence to prep for XP:
  8. fixboot
    fixmbr
    cd \
    ren windows winvista
    exit
Posted on May 09, 2010
Win XP instaling problem on Hp probook 6550b
Hope you are using a fresh windows XP install of the entire system.
HP drivers will need to be obtained and installed before running. The error on the screen usually is a driver error and not a XP issue.
Mar 15, 2014 | HEWLETT-PACKARD HP ProBook 6550b Notebook
Hp 650
You need the Recovery CD for your model HP laptop or a Windows XP installation CD plus the product installation code.
The product installation code is printed on the Windows XP label that is attached to the bottom of your laptop.
Feb 26, 2013 | HP 650 Notebook PC
Hp 110-3030NR just bought used, wants a password , will not boot without it, don't know where the f keys are, so can't get to safe mode
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
http://www.daossoft.com/knowledge/how-to-reset-hp-password-hp-laptop-password-recovery.html
Sep 18, 2011 | HEWLETT-PACKARD HP Mini 1103030NR Netbook
Sir, i have hp mini 210-1000 laptop without cd/dvd. while installing windows xp i have deleted the partitions & tried to install xp from usb but failed. please help me to install windows xp .
Check the BIOS to see if you can make the USB as the first boot device, if you can then you will be able to install XP from the USB flash memory stick.
The reason why your XP installation failed is because in most older laptops, the USB port does not work until Windows XP has been installed.
Your hard disk may have an Windows XP install partition that you can access to reinstall Windows, provided you have not deleted this partition.
Jul 10, 2011 | HP Mini 1000 XP Notebook
HP Deskjet 3740 Series
You have to go www.hp.com select your region and product then you have to choose OS and now you can printer's driver for free for life.
Your problem will solve.
Aug 04, 2009 | HP DeskJet 3740 InkJet Printer
How to install windows xp in hp pavilion dv4-1125nr series???
You should install Windows XP that came with your computer with the recovery program that is built-in with an HP computer. The Windows that comes with your computer includes all the drivers and software needed specifically for an HP Laptop.
Here's a link to HP's website outlining all the ways to Recover your Laptop and reinstall your Windows XP Operating System back to factory default including how to create a set of your own Recovery Disks:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00608578&cc=us&lc=en&dlc=en
Feb 01, 2009 | HP Pavilion dv4000 Notebook
Widows XP
(1) go to Hp.com - load load the necessary Xp drivers for your unit - burn them to cd - then aquire a replacement hdd - install Xp on that - install the required drivers and walla you have one hdd with vista and another with XP
Jan 21, 2009 | HP Compaq 6720s PC Notebook
Installing windows xp to compaq presario 700 pc notebook
HP Compaq Presario 700 series was originally designed for XP and Vista, therefore you can install XP on it.
After installing Windows XP, you will need to install all drivers.
You can download drivers and software for your laptop from HP here.
Oct 07, 2008 | Compaq Presario 700 470024-192 Notebook
Sounddriver for hp dv2401tu model
if u have sound driver problem in hp dv2401tu then insttal- hp dv2224ea modal audio driver after install uaa bus driver.ok
brijesh ameta
Oct 29, 2007 | Computers & Internet
HP Compaq nc6000 Notebook Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
