Question about Hotpoint Ultima WF860 Front Load Washer
WT960 Heater / electrics tripping out (solution not problem)
I've had issues with the electrics tripping out and have ad it repaired twice. The last repairer told me what the problem was and so when it happened again I fixed it myself.
The problem is caused by scaling. The element gets full of limescale and so trips out.
To replace the heater element first unplug the electrics!!!!
Remove the panel at te back (bottom) of the machine - 2 screws, on on the left and one on the top right of he panel.
You should see the motor on the left and to the right the electrics onto the heater element (see pic)
disconnect the spade fittings.
remove the sensor (carfully - it pulls out but for obvious reasons is a tight fit) - see pic
the element pulls out (see pic) but again it is very tight
replacement is the reverse.
The part no is 1604486 and the cheapest place I found for a replacement is
http://www.hotpointspares2u.co.uk/heating-element-1604486-p-37.html
Hope this helps someone - usual disclaimers apply i.e. you are advised to consult an eletrician, no liability accepted etc. etc.
  • clevertrevor Jul 19, 2008
    Ooops forgot the pic
  • clevertrevor Jul 25, 2008
    UPDATE :
    The element comes out easier if you undo the 10mm nut on the earth connector on the element. This is connected to a clamp plate on the other side thatsquashes the seal to make it water tight.
    When you fit the new one you need to tighten the nut to make it seal properly.
    I also founbd out that it was the sensor that was faulty and not the element. Don't know if you can buy these separately.
2 Suggested Answers
  • 323 Answers
SOURCE: I've had an issues on my Hotpoint WT761 Washing Machine tripping
take off the back and reset the overheat protection, it should be a little red button , maybe the unit was not reset when installed
Posted on Oct 03, 2009
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
I have a Bosch Powerstar Ae115 and the left cutout keeps tripping. It has worked great for 5 years. When i reset it, the water gets warm again(never hot as it was before). What could be causing it to trip?
Water leaking into elements. Bad PC board. Undersized breakers. Undersized main panel.
Bosch Powerstar is a computer that happens to heat water.
If your 5-year-old laptop computer was malfunctioning, you would not be surprised.
But for some reason (false marketing by manufacturers?), folks believe a tankless computer is going to last 20 years.
Moreover folks also believe tankless will provide endless hot water while saving money.
The whole idea of tankless saving money is a load of sales-BS that defies physics and common sense.
There are no service manuals... except bosch website has troubleshoot section in product manual.
Call a bosch-qualified service tech.
Go to Lowes and buy ordinary tank heater, and fix your heater today for only $250.
Tank-type electric water heater can be easily repaired and maintained by homeowner to last forever... that is a fact
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Gene
Jan 12, 2014 | Water Heaters
Hot water intermitten and also burning smell coming from Intermatic T103 Timer
Jan 2013. Yes very experienced. Multiple issues. Bad thermostat. Burned contacts on timer.
Let's break it down.
1) Water heater tripped:
29th the electric water heater reset button was tripped because ECO detected high heat from very-hot-water, or nearby burned wire, or loose wire, or bad thermostat.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Description of water heater:
40 gallon Rudd (Rheem), 2 thermostats and 2 elements indicates ordinary 240Volt water heater.
More information shows on label on side of tank, including valtage rating (208-240), and element wattage (usually 4500 watts).
Rheem-Ruud serial number, 3rd and 4th digit are year of manufacture.
3) Solution for water heater:
Tripping ECO reset button, Very hot water, and sometimes not-so-very-hot ... sounds like bad thermostat, and/or bad element. Replace both thermostats, and see if problem persists. Then replace elements if needed.
4) Information about timer:
Water heater circuit has 40 amp T103-Timer, which is plenty heavy for ordinary 240Volt household water heater that draws 19-22 amps.
T103 timer has repair parts, and can usually be repaired unless overheated contacts caused melting, but that can also be worked around in some circumstances, or the internal mechanism replaced by buying T103M mechanism-only and snapping into existing box.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
5) Solution for timer:
Attach photo of inside of T103 timer, and I can assess what steps will most likely fix the timer.
Maybe the timer is not connected to water heater.
Jan 02, 2013 | Intermatic T103 Indoor 120-Volt 40-amp...
Heat surge amish heater turns off and trips reset button
Do NOT use this unit as is!.
My experience is you have to pay to ship it for repairs and if out of warranty you should buy another heater. All electric heaters use the same power for the same heat unless its a heat pump, so save money and buy $30 WalMart heaters.
Nov 17, 2012 | Heating & Cooling
I have an 80 gallon Reliance water heater. It's about 3 years old and wired 240V. Within the last couple days it has tripped the breaker twice. There is nothing else on this circuit. What could be causing...
There is a heating element going bad and shorting out...
The best thing to do would be to replace both elements because it would be very hard to tell exactly which one is causing the problem...
heatman101
Mar 31, 2011 | RELIANCE ELECTRIC WATER HEATER
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
Jan 07, 2011 | Water Heaters
Hotpoint ultima wt960. washer keeps tripping the electric out. help
Try disconnecting the heater element, and see what happens.
If it still trips, then it is likely to be a problem with the motor.
Hope this helps.
Jan 05, 2010 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
288 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
