Question about Microsoft Xbox 360 Console
No video I cant get a picture or sound whne i plug in my old xbox the scart system kicks in and it finds its own channel on the tv. But the 360 does not (I dont have a tv remote) I used a multi scat switch box and when you swith half way between two scart sockets you can see the 360 screen although very fuzzy, so it is there
  • Anonymous Jul 19, 2008
    I plugged everything up to my xbox 360 snd for some reason it still wont turn on.
    Scholar:
  • 26 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio , video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Posted on Mar 13, 2009
  • 3 Answers
Did you try to unplug and replug the cable that makes sound and video
Posted on Jul 19, 2008
I have an old school Curtis mathes TV for my son Xbox 360 can not get right channel no code works any suggestion
The XBOX360 does not connect via any RF channels (TV aerial). It connects through either the analogue video & audio inputs e.g. SCART or PHONO connectors, or via HDMI (which will not be supported on your old TV). If you have connected via the SCART or PHONO type then you can select 'AV' or 'EXT' via the remote to get input from the SCART/PHONO.
Apr 15, 2016 | Curtis Televison & Video
I have a 27 inch syphonic flat screen tv and I'm trying to get it on an input channel in order to play my Xbox 360
I dont have a 360 so cant be 100% sure this will be helpful. i have a PS3 and to get it to run on HD after using it on SCART, you need to plug both the HDMI and SCART leads in simultaneously and go into the system visual settings and change it to a HDMI port.
after this you need to jsut unplug the SCART.
im hoping its a similar issue but just swapping the PS3 menu's with the 360 one.
Oct 06, 2012 | Televison & Video
Cant tune tv in to use xbox 360
Check the scart lead by substitution, try another source of input, (game machine or dvd player,) it,s not uncommon to find bad solder joints on the print, where the scart socket is soldered to the mother board of the telly. there is no tuning as such for scart sockets, but you can get them in the wrong mode? S-video etc? but you should, in that case, get some sort of picture. Good luck! Nick
Mar 23, 2010 | Televison & Video
Xbox 360 plays movies fine but colour is wrong on games
i will suggest if you new tv has more inputs, just try a different imput, and make sure the plugs are in all the way. this is a new tv so it will be tight.
same with the video connection on the back of xbox well plugged and straigt.
hope this woks. and remember to rate me if i helped you
Oct 09, 2009 | Microsoft Xbox 360 Console
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
May 12, 2009 | Microsoft Xbox 360 Elite Console - Black
XBOX 360 NO PICTURE
if using hd tv then use the cable with the blue lead, if not using hd tv then use the red, white and yellow leads. If using the scart connection to put the leads into make sure that you have it set to the correct av or ext channel
Dec 28, 2008 | Video Game Consoles & Games
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
Can't find right channel for xbox 360
on your television?
xbox360 comes standard with a scart cable so its not on a channel as such, try changing the source using the remote control for the television, it should come up with an AV or EXT channel. if still no luck ensure that the scart is correctly inserted into the slot (it sounds stupid but they fall out very easily and can cause loos of picture or sound or both)
Jul 08, 2008 | Video Game Consoles & Games
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
78 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
