Question about SmartDisk 250GB SMARTDISK CROSSFIRE EXT Hard Drive
External drive seems to freeze up everything, including desktop when USB plugged in
I have a lot of info that I need on this drive. The green light is on when power plugged in and seems to be working. If I plug in the USB cord to my desktop, everything freezes and the green light goes on an off and nothing is being read; although there is noise from the drive as if something is happening. If I have everything plugged in (USB, power supply) and turn on the unit, everything freezes and the green light goes on and off... again, the drive is making noise like it is trying to read, but nothing happens. Any ideas?
  • 1 more comment
  • Tommy Williams Jul 19, 2008
    Part two to my previous post. After just walking away and just letting it stay for a while, I check out everything and it shows the drive is there and supposedly working properly through device manager. When I look on "my computer" it is just listed as "local disk" and not formally named by brand as it usually was. I right clicked on it and my computer froze for a while and then eventually a message "Disk in Drive "X" is not formatted, Do you want to format it now?" Yes or No... I don't think this is good... Help?!
    One more addition! :) I meant to say double clicked not right clicked on the drive while in "My Computer" before the freeze and formatting message...
  • Anonymous Mar 22, 2014
    ND250
  • 304 Answers
Do not panic. The problem is with the controller in the external case and not the HD itself. Open the case and remove the hard drive. Bring it to circuit city or best buy and invest in a new HIGH QUALITY external case for your hard drive. An associate at either of these stores will be able to tell you the exact case you will need.(SATA,E-IDE,IDE,ect...) DO NOT BUY the cheapo $10 cases you can get on the net. There is a reason some cases cost more then others and the main reason is the quality of the internal components and the durability of them. Install Your HD in your new case(very simple) and you will be up and running in no time.
I Hope this helps you out and you appreciate my help enough to remember to rate me FixYa when you are all fixed up.
Feel free to contact me with any of your other technical needs,
as always my help is free...This is my hobbie...
George
Posted on Jul 19, 2008
  • George Kohler
    George Kohler Jul 23, 2008
    Hello, if you need more help feel free to send me your Phone # in an E-mail to geokohler@gmail.com. Describe your problem a little.
    I will call you for free to help you further,
    George
Iomega External Hard Drive is not recognized or not detected. External drive does not appear on the desktop. I have had this hardrive for a while and it is about at half capacity. When I plug in the USB to...
Yes, seems that the USB controller is not working properly, Try buying an external HDD case and insert your HDD into it. Its just a plug and play setup. Hopefully it will fix your problem.
Jun 10, 2017 | Computers & Internet
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green...
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Nov 05, 2012 | Buffalo Technology Buffalo MiniStation...
Rocstor external harddrive disappears from desktop. Why?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 05, 2012 | Rocstor Storage Rocstor Rocpro 225 500 GB...
Rocstor icon disappears from desktop and light is half orange/green
hope this helps you
Nexxtech external USB hard drive stopped working. Light comes on but drive does not seem to activate and produces no response in the laptop.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
a cnet rview
Pros: Lots of space, very low price, doesn't require outside power
Cons: Sometimes stops working, no firewire (but still a quick transfer speed)
Summary: This doesn't require outside power, but sometimes you need to hook it up to 2 USB ports. The USB cable has 2 heads. Sucks when I only have 3 USB ports on my laptop.
Also sometimes it spontaneously stops communicating with the computer. I don
Oct 04, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
The drive is no longer recognized by the computer. When I plug it in the computer slows and freezes. When I unplug it the computer goes back to normal. Drive is Buffalo Drive Station External USB 2.0...
if your computer came with a motherboard disc the drivers could be on it
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
May 02, 2011 | Buffalo Technology DriveStation HD-HC500U2...
My desktop does not recognize the 320GB USB External HD
hope this helps
Apr 25, 2011 | Western Digital Passport 320GB External...
I have a Seagate Free Agent Desktop External Hard Drive. I cannot get any of my computers to access the drive. I fear the drive has crashed.
get linux puppy and boot the cd while your hard drive is plugged in, if you can mount under puppy linux and see your info choose the info you need and offload onto an external usb, copy the files over, dont move them as if disk is corrupt you could lose info, then reformatt the drive, just to let you know there seems to be alot of hard drive issues with seagate lately
Feb 14, 2011 | Seagate Computers & Internet
The hitachi 500gb usb 2.0 external hard drive. This drive will not show up on any computer that I plug it into. When i turn it on the red light comes on, but no green. my computer crashed and...
Assuming that you have installed a fresh windows installation after crash, you might not installed the usb drivers.
to make sure that the usb drivers are installed and correct drivers go to controlpanel->system->device manager.
and check in that no yellow icons are present in the usb.
you said that the red light is on. that is power indicator and no data transfer.
green light indicates power and data transfer is on.
check your drivers and try to update or reinstall if the drivers are already present.
CAUTION: before reinstalling or updating see that you uninstall the previous drivers.
Apr 21, 2009 | Computers & Internet
SmartDisk 250GB SMARTDISK CROSSFIRE EXT Hard Drive Logo
264 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
