Question about Toshiba Satellite Pro 6100 Notebook
Hinge Cover Thank you for your time, I have looked and see no way to remove the hinge covers, mine has the speakers next to the hinges
    Genius:
  • 2,028 Answers
Ahh, yes, with these you have to remove the entire plastic piece with the speaker covers. If you need anything else let me know.
Posted on Jul 19, 2008
Acer aspire 5253 power button broken due to hinge
Have a repair shop or person look at this---it may be fixable now but if you keep using it the issue may get worse.
Nov 05, 2012 | Acer Aspire 5532 15.6" Laptop Original...
Tip
How to remove the hinge cover on a Gateway PA6A, MX8711 1. You will need to is...
1. You will need to is unscrew the two screws that are on the back of ether side of the hinge cover.
2. Next take small screw drivers gentle pry up on the right hing cover. Note this piece is designed to flex a little.
3. Then lift up on the hinge cover slowly and it should release. Note you may need to pop the left side cover with a screw driver.
At this point you should have the hinge cover off
on Mar 24, 2010 | Computers & Internet
Left hinge broke on lexmark pro 905
Not a perfect fix, but this is what I did: There are 2 spring-loaded pistons located on the printer side of the hinge that cause this problem. I think there should be another piece of plastic that holds the top of the printer hinge down on these springs, but when this hinge is gone, the top of the printer is held upward by them. If you use some pliers to gently pull these spring-loaded pistons upward, you can easily pull them out, followed by the springs they cover. Once removing these, the top of the printer lies flat. The top is still unstable, but mine will now feed paper just fine and closes. Hope this helps! WebRepOverall ratingThis site has no rating(not enough votes)
Oct 23, 2012 | Lexmark Platinum Pro905 multifunction...
Change doors from left to right
Depending on the brand, this "may" be possible. Look for a mounting bracket area on the side you want to change to. Is so, have someone help you, two person job!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Refrigerators
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
2002 honda odyssey power sliding door roller replacement. Is this a hard job to do?
Not very difficult if like my '99. Be sure to purchase the correct hinge for "power" door. Here are the steps:
  • Remove rear tail light (2 screws and pull from socket)
  • Remove two screws from rear of hinge cover panel
  • Remove bolt from front of hinge cover panel
  • Open door around one foot and rest the back end on something about the same height
  • Remove the three bolts from the hinge connecting it to the door
  • Loosen slack on cable by unbolting pulley under inside rear panel (tire tool storage on driver side)
  • Slide broken hinge out back of rail
  • Replace new hinge and put all back together
I don't know if there is a simpler way to loosen the slack on the cable, but this is how I did mine.
Hope this helps.
Jul 20, 2010 | 2001 Honda Odyssey
When i move the screen of the laptop the sound goes off
I know the answer to this one from experience, one of the wires to the speakers is broken in the area of the right hinge cover.
Remove the hinge cover and you will see the bundle of wires for the speakers and LEDs on the LCD assemble, carefully inspect the wires and you should find the broken one. If you are VERY careful and have a steady hand, you can splice the wire back together and have sound. Once I fixed mine, I also lightly re-routed the wires to limit the amount of chafing.
Apr 18, 2010 | Dell Inspiron 710m Notebook
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hinges for top cover for HP officejet 6210- Q5820A
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
How do I remove the doors?
Refrigerator side is easy. Remove the top hinge cover and then the hinge. Lift it off the bottom hinge and set it to the side. The freezer side is a little more entailed as it has a water and electric connection. Remove the lower kickplate (Grille) and then you will see a plastic tube coming out the bottom of the hinge. Follow it to the connector and removed it. A little water might come out but it will stop. Next, go to the top hinge and remove the hinge cover. Unplug the electric connection and then remove the top hinge. Lift the door off the bottom hinge sliding the plastic tubing through the hinge...This should do it. If you need further asssistance, we are here.
Eric Campion
Feb 21, 2009 | Frigidaire FRS23KF7AB Side by Side...
Toshiba Satellite Pro 6100 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
